You are here: Point Clouds > PointCloudPropertyExtractor
Extracts the properties of a point cloud feature and exposes them as attributes. The attribute values are for reference only and may become out of date if the point cloud properties change.
The following attribute is always exposed:
_num_points
Additional attributes may be exposed for each component.
Transformer Categories
Calculated Values
Point Clouds
Search FME Knowledge Center
Tags Keywords: point "point cloud" cloud PointCloud metadata LiDAR expose extract extents sonar
