You are here: Coordinates > ReprojectAngleCalculator
Converts a given angle from one coordinate system to another. The transformer uses the first coordinate of the passed-in feature and returns the angle of the specified line at the determined angle in the destination coordinate system. It is useful for converting data such as text rotations that are established in many systems in the destination coordinate system units.
To calculate the new angle, the transformer uses the:
  • input length
  • input angle
  • input point
  • source (reader) coordinate system
  • destination (writer) coordinate system
and then calculates a second point in the source coordinate system by taking the first point and advancing length units in the angle heading. It then reprojects both points to determine the new angle.
This function assumes all coordinate systems are Cartesian.
Transformer Categories
Calculated Values
Coordinates
Search FME Knowledge Center
