You are here: Rasters > RasterDEMGenerator
RasterDEMGenerator
Constructs a Delaunay triangulation based on input points and breaklines. That triangulation is then uniformly sampled to produce a raster digital elevation model (DEM raster).
Output
  • If a set of individual 3D points comprising a DEM is required, you should use the DEMGenerator.
  • This transformer is unaffected by raster band and palette selection.
Example
Transformer Categories
3D
Rasters
FME Licensing Level
Transformer History
This transformer was previously named DEMGridGenerator.
Search FME Knowledge Center
Tags Keywords: MBR "minimum bounding rectangle" raster grid generate DEM elevation numeric create point DEMRasterGenerator DEMGridGenerator pointcloud
