You are here: Rasters > RasterHillshader
RasterHillshader
Generates a shaded relief effect, useful for visualizing terrain.
Each selected input band will be converted to a GRAY8 band with hillshade values between 0 and 255. Additionally, if Interpolate Nodata is set to No or if the band has a nodata value, an additional ALPHA8 band will be generated, with a value of 0 where the input was nodata and a value of 255 where the input was data.
Note that the horizontal and vertical units are expected to be equal. If this is not the case, the Scaler may be used prior to this transformer to apply an appropriate scale factor.
This transformer supports raster band selection. The RasterSelector can be used to modify this selection.
Transformer Categories
3D
Cartography and Reports
Rasters
FME Licensing Level
Search FME Knowledge Center
