PinterestConnector
Accesses the Pinterest social network service to create, edit, download, or delete Pins and Boards or list Pin/Board information from a Pinterest account.
- Manage data on Pinterest by creating, downloading, and deleting Pins and Boards
- Transfer a Pin's contents into or out of an attribute in FME
- View downloaded Pinterest data using the Data Inspector
- Retrieve Pin and Board names, paths, links and other information from Pinterest to use elsewhere in a workspace
The PinterestConnector uses your Pinterest account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the social network.
Depending on your choice of actions, it will create, edit or download Pins, Boards, and features; list information from the service; or delete items from the service. On create and edit, link attributes can be added to the output features. On List and Download actions, links and Pin/Board information are added as attributes.
In this example, the PinterestConnector is used to download a Pin as a feature from Pinterest. After creating a valid web connection to a Pinterest account (which can be done right in the Pinterest Account parameter), and browsing to a Board, the Object ID is retrieved, and output attribute names are specified.
An Inspector is added to inspect the geometry of the newly downloaded feature. The feature, along with its attributes, will be sent to the Data Inspector to view the Pin’s image and see a table view of the output attributes.
In this example portion of a workspace, the PinterestConnector is used to create a new Pin on a specific Board, it will then be emailed out to users.
The Pin is created using the PinterestConnector transformer, and filling in the desired information. It is then sent out to the specific users using the Emailer transformer.
The Emailer transformer will allow the user to send out a message to other users that a new Pin has been created and provides them a link to view it.
To specify the link and message to be sent the user, the body in the message section of the transformer dialog needs to opened and filled out. The shareable link can be inserted by adding it into the message from the “FME Feature Attributes”.
This transformer can only create a Pin using .png, .jpg, or.gif images.
The output of this transformer will vary depending on the Pinterest Action performed.
After a Create and Edit action, URLs to the Board/Pin may be saved to the Shareable Link attribute, and the ID of the Board/Pin will saved to an attribute.
- A Download action can save to a feature.
- A Delete action has no output ports.
- A List action will output a new feature for each Pin found in the Board specified. Each of these new features will have attributes listing various pieces of information about the object.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
| Pinterest Action |
The type of operation to perform. Choices include:
| Pinterest Account | Performing operations against a Pinterest account requires the use of OAuth2 authentication using a Web Connection. To create a Pinterest connection, click the 'Pinterest Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
The remaining parameters available depend on the value of the Request > Pinterest Action parameter. Parameters for each Pinterest Action are detailed below.
Features
Create |
The type of data to be created.
Board |
The name of the Board to create the Pin in, if Create is set to Pin. |
Name |
The name of the new Board to be created, if Create is set to Board |
Link (optional) |
The outgoing link attached to a Pin, if Create is set to Pin. |
Description |
The description of the Pin or Board. |
Image URL |
The link to an image to be displayed for Pin, if Create is set to Pin. |
Output Attributes
Default attribute names are provided, and may be overwritten.
| Sharable Link |
Specify the output attribute that will store a publicly accessible URL that links to the Pin or Board on Pinterest. |
Pin or Board Id |
Specify the output attribute that will store the ID of the Pin/Board that was just created. |
Pinterest Path
Object ID |
The Object ID of a Pin on Pinterest to delete. If valid credentials have been provided as a web connection, you may browse to a location. |
Pinterest Source
Object ID |
The Pinterest ID of the Pin to download. If valid credentials have been provided as a web connection, you may browse to a location. |
Download as |
Output Attributes
Name |
Specify the attribute to hold the name of an object on Pinterest. |
Pin or Board ID |
Specify the attribute to hold the ID of an object on Pinterest. |
Pin Link |
Specify the attribute to hold the link to an object on Pinterest. |
Pin Type |
Specify the attribute to hold the type (Pin or Board) of object. |
Image URL |
Specify the attribute to hold the image URL of the object. |
Edit Features
Edit |
The type of data to be edited.
Object ID |
ID of the object to be edited. |
Board (optional) |
The name of the Board to move the Pin to, if Edit is set to Pin. |
Description (optional) |
The new description of the Pin or Board. |
Link (optional) |
The new outgoing link from Pinterest, if Edit is set to Pin. |
Name (optional) |
The new name of the Board, if Edit is set to Board. |
Output Attributes
| Sharable Link |
Pin or Board Id |
Specify the output attribute that will store the ID of the Pin/Board that was just edited. |
Pinterest Path
Object ID |
The Board ID on Pinterest to list the contents of. If valid credentials have been provided as a web connection, you may browse to a location. |
Output Attributes
Board Name |
Pin or Board ID |
Pin Link |
Pin Type |
Specify the attribute to hold type (Pin or Board) of object. |
Relative Path |
Specify the attribute to hold the path to the Pin on Pinterest. |
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| Dependencies | Pinterest account |
| History | Released FME 2018.0 |
| Categories |
FME Knowledge Center
Search for all results about the PinterestConnector on the FME Knowledge Center.
