Retrieves the coordinate system of the feature into an attribute.
If the feature has no coordinate system, the attribute will be an empty string.
 Input
Input
 Output
Output
                                            Features with the extracted coordinate system leave through this port.
 Coordinate System Attribute
                                            The name of the attribute that will record the coordinate system of the feature.
Using a set of menu options, transformer parameters can be assigned by referencing other elements in the workspace. More advanced functions, such as an advanced editor and an arithmetic editor, are also available in some transformers. To access a menu of these options, click  beside the applicable parameter. For more information, see Transformer Parameter Menu Options.
Transformer Categories
Transformer History
This transformer was renamed from CoordinateSystemFetcher.
Search FME Knowledge Center
Tags Keywords: CoordinateSystemFetcher
