You are here: Rasters > RasterAspectCalculator
Calculates the aspect (direction of slope) for each cell of a raster. Aspect is measured in degrees from 0 to 360, starting clockwise from the north.
Each selected input band will be converted to a Real64 band with output values that represent the aspect. If an input band does not have a nodata value, the output band nodata value will be set to -1.
This transformer supports raster band selection. The RasterSelector can be used to modify this selection.
Transformer Categories
Calculated Values
Rasters
FME Licensing Level
Search FME Knowledge Center
