Copies an existing component to a new component with the specified name. The existing component remains and a new component is created that has a different name, but the same values.
 Output
Output
                                            The updated features are output through this port.
 Source Component
Source Component
                                            The source component to copy from.
 Target Component
Target Component
                                            The target component to copy to. If this component already exists, it will be overwritten.
Using a set of menu options, transformer parameters can be assigned by referencing other elements in the workspace. More advanced functions, such as an advanced editor and an arithmetic editor, are also available in some transformers. To access a menu of these options, click  beside the applicable parameter. For more information, see Transformer Parameter Menu Options.
Transformer Categories
FME Licensing Level
Search FME Knowledge Center
