Provides the ability to set up an aggregate where each part is independent from the others, and its own complete geometry.
 Aggregate
Aggregate
                                            Aggregates will be sent out via the Aggregate port.
 <Rejected>
<Rejected>
                                            This transformer works only on aggregates, so features containing any other geometry type will be sent to the <Rejected> output port.
 Set to Contain Multiple Geometries
                                            When this parameter is set to No, the aggregate will represent a single geometry comprising multiple parts
When this parameter is set to Yes, each part in the aggregate will be interpreted as its own separate geometry, independent from the other parts.
Using a set of menu options, transformer parameters can be assigned by referencing other elements in the workspace. More advanced functions, such as an advanced editor and an arithmetic editor, are also available in some transformers. To access a menu of these options, click  beside the applicable parameter. For more information, see Transformer Parameter Menu Options.
Transformer Categories
Transformer History
This transformer was previously named IndividualGeometriesSetter.
Search FME Knowledge Center
Tags Keywords: aggregate individual multiple many "multiple geometry" multigeometry IndividualGeometriesSetter
