AttributeKeeper
- Cleaning up features with large numbers of unnecessary attributes
Once connected to input features, the AttributeKeeper provides pick lists (one for attributes and one for list attributes) for you to choose which attributes to retain. All other attributes are removed, and the modified features are output.
Geometry and FME attributes are not removed.
Format attributes will be removed whether exposed or not . Exposed FME attributes will simply be hidden - not removed permanently.
In this example, two attributes are selected from the pick list to keep.
The Attributes to Keep parameter is populated with those choices.
As the features exit the transformer, all of the unwanted attributes have been removed, including all lists:
- If the number of attributes you want to keep is greater than the number of attributes you want to remove, consider using the AttributeManager.
 - Use the AttributeManager to remove selected individual attributes from a feature.
 - Use the BulkAttributeRemover to remove all attributes that match a pattern.
 - To keep a Format attribute, expose it first, either in the reader or by using the AttributeExposer
 - If you choose to keep a list element attribute, for example member{0}.type, it won’t appear under the transformer unless this element has already been exposed. See Exposing List Attributes for more information.
Features with only those attributes selected for retention within the transformer.
After the AttributeKeeper is connected, click the browse button to display the list dialog. Select the attributes that you want to keep on the feature. The unchecked attributes will be removed, except for any FME attributes.
Format attributes will be removed, whether exposed or not.
After you connect the transformer, click the browse button and select the lists to keep.
Note that if you select to keep a list, your selection will include any list attributes or nested lists. For example, if you select to keep a list called
list{}
then list{}.attr or list{}.sublist{} will also be kept.
The Lists to Keep parameter is a way to keep an entire FME list (for example member{}.type). To keep specific list elements (for example member{0}.type) select them under Attributes to Keep.
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
                                                         Processing Behavior  |
                                                         Feature Holding  |
                                                         No  |
| Aliases | ListKeeper |
| History | |
| Categories |
FME Knowledge Center
Search for all results about the AttributeKeeper on the FME Knowledge Center.
