You are here: Rasters > RasterBandMinMaxExtractor
Extracts the band minimum and maximum values, palette minimum and maximum keys and palette minimum and maximum values of a raster feature and exposes them as attributes.
The attribute values are for reference only at one point in the workspace and may become out of date if the raster properties change.
The following band and palette properties are exposed:
_band{}.min
_band{}.max
_band{}.palette{}.keyMin
_band{}.palette{}.keyMax
_band{}.palette{}.valueMin
_band{}.palette{}.valueMax
Note that wherever "{}" appears, there will be one instance of the attribute for each band or palette. The first will appear with {0}, the second with {1}, and so on.
Related Transformers
This transformer only extracts band and palette minimum and maximum properties. To extract other band properties, use the RasterBandPropertyExtractor. To extract raster geometry properties, such as the number of rows and columns, use the RasterPropertyExtractor.
  • This transformer accepts only raster features.
  • Note that the any nodata values that are present on the band are ignored in the minimum and maximum value calculations.
  • This transformer is unaffected by raster band and palette selection.
Transformer Categories
Calculated Values
Rasters
FME Licensing Level
Search FME Knowledge Center
