You are here: Point Clouds > PointCloudStatisticsCalculator
Calculates statistics on point cloud components and exposes them as attributes.
Statistics are calculated and output on each point cloud feature individually. If you want to calculate point cloud statistics on a group of point clouds in aggregate, merge them prior to this transformer with the PointCloudCombiner.
Transformer Categories
Calculated Values
Point Clouds
Search FME Knowledge Center
