You are here: Web > WebMapTiler
WebMapTiler
Creates a series of image tiles that can be utilized by web mapping applications such as Bing™ Maps, Google Maps™, or Web Map Tile Service. This is done by resampling rasters to various different resolutions and then splitting them into tiles.
Tile Schemes
  • Generally, when writing out the rasters generated by this transformer, one would fanout the destination feature type on the quadkey for Bing Maps or a combination of the zoom level, tile column, and tile row for Google Maps. The PNGRASTER writer is recommended for the best results.
  • This transformer accepts only features that have raster geometry and is unaffected by raster band and/or palette subselection.
  • Note that for the best performance, rasters output by this transformer should be written in the order they are output. Changing the order (for example, by using Dataset Fanout or a Sorter transformer) may negatively impact performance. Alternatively, use a RasterCheckpointer after the WebMapTiler, but prior to the operation that changes the order.
Transformer Categories
Cartography and Reports
Format Specific
Rasters
Web
FME Licensing Level
Transformer History
This transformer was previously named the VirtualEarthTiler.
Search FME Knowledge Center
Tags Keywords: raster grid band "virtual earth" Bing Google "web map" webmap mapcruncher pyramid clip tile subset quadkey VirtualEarthTiler
