You are here: Strings > AttributeCompressor
AttributeCompressor
Compresses and (optionally) encrypts the values of the specified attributes. The compressed and encrypted attribute values can be decompressed and decrypted using the AttributeDecompressor.
This transformer is particularly useful for compressing large blocks of XML, or geometry-storing attributes.
Jump to Configuration
  • Password-encrypt a value for storage in a database, for decryption with the AttributeDecompressor
  • Compress large blocks of XML to optimize storage
  • Compress large geometry for storage as blob fields to optimize storage
The AttributeCompressor lets you pick one, some, or all attributes to be compressed, and select the level of compression to apply. You can choose to encrypt the compressed attributes with a user-provided password, or leave them unencrypted. Features passing through the transformer are output with their attribute names unchanged, but the selected values compressed. The AttributeDecompressor can be used to read them, either elsewhere within the workspace or in a different workspace.
  • The AttributeCompressor uses the zlib library to provide basic compression, and the OpenSSL library to provide encryption.
  • Different datasets have varying degrees of compressibility, and so results will vary.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
FME Licensing Level FME Professional Edition and above
Aliases
History
Categories
Attributes
Strings
FME Knowledge Center
Search for all results about the AttributeCompressor on the FME Knowledge Center.
