GeographicBufferer
Creates a buffer zone of specified size around or inside input geometry. Works similarly to the Bufferer, but is designed for use with features in Geographic coordinates. Reprojects input features into the Dynamic Equal Distance projection, buffers them, then reprojects back into the original Geographic coordinates.
- Creating fixed size zones around features, such as rights-of-way or setbacks
- Determining spatial relationships based on proximity
- Creating variable size zones around features to represent attribute values
- Creating a buffer in different units than the input data
The GeographicBufferer accepts 2D point, curve (line), and area geometries. It reprojects the input features, including those with geographic (lat/long) coordinates, to Dynamic Equal Distance projection, and then creates buffers according to the parameter settings for units, size, and style.
The buffers are then reprojected to match the original coordinate system of the input features, and are output.
Point and lines may be expanded, creating surrounding polygons with points offset by the specified Buffer Amount in ground units. Areas may be expanded or shrunk, using positive or negative Buffer Amounts.
The attributes of the original features are retained, and the buffer is output, discarding the original geometry.
A selection of end cap and corner styles is available.
In this example, we create buffer zones around rapid transit lines. The source data is KML, in a geographic lat/long projection.
As the ground units are in degrees, the data must be reprojected before making calculations in units like meters or feet. The GeographicBufferer will take care of that.
The lines are routed into the Input port.
In the parameters dialog, we select Meters as our ground unit of choice, and set a Buffer Distance of 150.
The resulting Output buffer polygons retain the attributes of the original features, and are projected in the original lat/long coordinate system.
For more examples of using buffering, see Bufferer.
- This transformer creates buffers that are of equal width on either side of a linear input feature. To create offsets to either the left or right-hand side of a feature, use the OffsetCurveGenerator along with a Reprojector.
- To buffer features not in Geographic (lat/long) coordinates, consider the Bufferer.
- Areas will be buffered on one side only - externally for a positive Buffer Amount, and internally for a negative Buffer Amount.
- Features must have a coordinate system defined, or they will be output via the Rejected port. The CoordinateSystemSetter may be of use to specify coordinate system if it is missing.
- The GeographicBufferer will buffer features in any valid coordinate system (geographic or other), and so may be used to create flexible workspaces that can buffer regardless of input coordinate systems and units.
Points, curves (lines), or areas. Only 2D geometries are accepted as input, and they must have a valid coordinate system defined.
Each point in the output curve will be the specified amount, measured in ground units, away from the input geometry. If the specified buffer amount is too small, a feature with a null geometry is output.
The original geometry is not output.
Features without a coordinate system defined, or without valid point, curve, or area geometries are output through this port along with an additional attribute, fme_rejection_code, to indicate the reason for rejection.
Buffer Distance Unit |
This parameter specifies the measurement units used by the Buffer Distance parameter. Choices include:
Buffer Distance | If a positive (negative) buffer amount is specified, the input feature is expanded (shrunk). A buffer amount of 0 will leave the input geometry unmodified. |
End Cap Style |
When buffering a line, you can specify the end-cap style. As these diagrams illustrate, these caps can be Round (default) or Square, but you can also set this parameter to None. Round
Square
None
Corner Style |
When buffering a line or area, you can specify the corner style. As the diagrams below illustrate, the corner styles can be Round (default), Bevel (chopped), or Miter (pointed). If Miter is used, a limit must be specified using the Miter Limit parameter. If a corner is too pointed for the miter limit, the corner will instead be bevelled. Round
Bevel
Miter
Interpolation Angle |
This parameter controls the smoothness of the stroked arcs in the output buffer boundaries. It specifies what angles should be used to construct a circular arc. As this parameter decreases in value, the smoothness of the arc connectors increases. This parameter is used for the Round End Cap Style and the Round Corner Style. The value must be between 0 and 90 degrees. |
Miter Limit |
Miter Limit This parameter controls how pointed a buffered corner can be before it is beveled. It is the highest value that the ratio of corner distance to offset is allowed to have before truncation occurs. A higher number allows for more extreme corner angles.
Miter Ratio = Corner distance / Offset
A set of control characters is available in the Text Editor. | |
Working with User Parameters | Create your own editable parameters. |
Dependencies | |
FME Licensing Level | FME Professional Edition and above |
Aliases | |
History | |
Categories |
FME Knowledge Center
Search for all results about the GeographicBufferer on the FME Knowledge Center.
