AttributeReprojector
Reprojects coordinates stored as attributes from one coordinate system to another.
- Reprojecting coordinates stored as attributes (not geometry) to the desired coordinate system
- Adding additional coordinate pairs as attributes, in alternate coordinate systems
The AttributeReprojector accepts any feature. The user specifies the attributes containing x and y coordinates, and supplies both the source and destination coordinate systems.
The transformer reprojects the coordinates according to these selections, and updates the x and y attributes to the new values, overwriting the originals.
This transformer does not alter the feature’s geometry – only the values of the selected X and Y attributes (if they contain coordinate values) are changed.
Accurate results depend on the user’s correct selection of the source coordinate system.
In this example, we start with a CSV file of drinking fountain locations. A CSV dataset has no geometry, but it does contain coordinates for the fountains, in a UTM projection.
The CSV features are routed into an AttributeReprojector.
In the parameters dialog, the x and y attributes containing the coordinates are specified accordingly, the source coordinate system entered (as UTM83-10), and the new destination coordinate system chosen (LL-WGS84).
The new coordinates are calculated and replace the existing attribute values. The transformer does not create geometry, it only supplies values.
In this example, we start with a CSV file of drinking fountain locations, which has no geometry. It contains coordinates for the fountains, in a UTM projection. We want to add an additional coordinate system’s coordinates to it, to provide options for users who may not have access to software that will reproject it for them.
The CSV features are routed into an AttributeManager, and then to the AttributeReprojector.
In the AttributeManager, we add two new attributes, named x_LLWGS84 and y_LLWGS84. Using the Attribute Value column, we copy the current x and y coordinates (still in UTM) from the x_coord and y_coord attributes.
In the AttributeReprojector parameters dialog, the x and y attributes are set to the new (copied) attributes, and the Source and Destination coordinate systems chosen.
The output now contains both sets of coordinates - the original UTM and new LL-WGS84.
The features that contain the attributes you want to reproject.
All processed features are output through this port.
X Attribute | Choose which X attribute to reproject. |
Y Attribute | Choose which Y attribute to reproject. |
Source Coordinate System | Choose from recently accessed coordinate systems, or click the browse button to access the Coordinate System Gallery. |
Destination Coordinate System | Choose from recently accessed coordinate systems, or click the browse button to access the Coordinate System Gallery. |
A set of control characters is available in the Text Editor. | |
Working with User Parameters | Create your own editable parameters. |
Attribute Reprojections
Geometry Reprojections
Dependencies | |
FME Licensing Level | FME Base Edition and above |
Aliases | |
History | |
Categories |
FME Knowledge Center
Search for all results about the AttributeReprojector on the FME Knowledge Center.
