PointOnAreaOverlayer
Performs a Point in Polygon overlay. Points receive containing area attributes, and areas receive contained point attributes (spatial join).
- Finding which areas that points fall inside
- Finding which and how many points are contained within areas
The PointOnAreaOverlayer compares points and polygons. Each point receives the attributes of the area(s) it is contained in, and each containing area receives the attributes of each point it contains.
Intersections between area features are not computed. FME consider points on the boundary of an area as “in”, and so if a point falls exactly on the line between two polygons, it will be considered "in" both areas.
Aggregates can either be deaggregated before processing or rejected.
In this example, we have a point dataset of food vendors and a set of polygons representing neighborhoods.
To find which neighborhood a vendor is in, we connect the food vendor points to the Point input port, and the neighborhoods to the Area input port.
In the parameters dialog, the default settings will provide the correct results. Note that the Attribute > Accumulation Mode is set to Incoming, which will add attributes from the containing neighborhood polygon to each point.
Looking at the food vendor points output, we can see that the containing neighborhood attributes have been added.
Looking at the area output, the _overlaps attribute tells us how many food vendors exist in each neighborhood.
Using the same food vendor points and neighborhood polygons as the previous example, we can also build a list attribute that contains all of the food vendors for a given neighborhood.
In the parameters dialog, enable Generate List on Output ‘Area’, give the list a name, and select the attributes to be included.
Inspecting the output, we can see that the Fairview neighborhood contains 7 food vendors, and the names and descriptions of those vendors are contained in a list attribute.
- If you have a lot of features to process, you can improve overlay performance by also using the Clipper transformer. The Clipper also provides different options for a point that falls exactly on a line. See the Clipper example from the FME Knowledge Center for information on how to use less memory using the Clippers First parameter.
- If you have a lot of Point features in particular, you can reduce memory usage of the PointOnAreaOverlayer by using the Areas First parameter.
- Note that where Point geometries are expected as input, PointCloud geometries are not supported.
- The PointOnAreaOverlayer does not have a tolerance option for position.
Transformer |
Can Merge Attributes |
Alters Geometry |
Counts Related Features |
Creates List |
Supported Types* |
Recommended For |
SpatialFilter | Yes | No | No | No |
SpatialRelator | Yes | No | Yes | Yes |
AreaOnAreaOverlayer | Yes | Yes | Yes | Yes |
LineOnAreaOverlayer | Yes | Yes | Yes | Yes |
LineOnLineOverlayer | Yes | Yes | Yes | Yes |
PointOnAreaOverlayer | Yes | No | Yes | Yes |
PointOnLineOverlayer | Yes | Yes | Yes | Yes |
PointOnPointOverlayer | Yes | No | Yes | Yes |
Intersector | Yes | Yes | Yes | Yes |
Clipper | Yes | Yes | No | No |
NeighborFinder | Yes | In some cases | No | Yes |
TopologyBuilder | Yes | Yes | No | Yes |
When there are multiple ways to configure a workspace to reach the same goal, it is often best to choose the transformer most specifically suited to your task. As an example, when comparing address points to building polygons, there are a few ways to approach it.
The first example, using a SpatialFilter to test whether or not points fall inside polygons, produces the correct result. But the SpatialFilter is a fairly complex transformer, able to test for multiple conditions and accept a wide range of geometry types. It isn’t optimized for the specific spatial relationship we are analyzing here.
With a SpatialFilter:
The second example uses a PointOnAreaOverlayer, followed by a Tester. The features output are the same as in the first method, but the transformer is optimized for this specific task. The difference in processing time is substantial - from 54.3 seconds in the first configuration, down to 13.7 seconds in the second one.
With a PointOnAreaOverlayer and a Tester:
Point (including text) features against which areas will be compared.
Area features against which points will be compared.
Point features, with attributes added according to transformer parameter configuration. Geometry is unmodified.
Area features, with attributes added according to transformer parameter configuration. Geometry is unmodified.
Features with invalid geometries will be rejected and output via this port.
INVALID_POINT_GEOMETRY_TYPE
INVALID_POLYGON_GEOMETRY_TYPE
INVALID_POLYGON_GEOMETRY_VERTICES
INVALID_POLYGON_GEOMETRY_DEGENERATE
EXTRA_POLYGON_FEATURE
Group By | The default behavior is to use the entire set of features as the group. This option allows you to select attributes that define which groups to form. |
Parallel Processing |
Select a level of parallel processing to apply. Default is No Parallelism. ![]() Note: How parallel processing works with FME: see About Parallel Processing for detailed information. This parameter determines whether or not the transformer should perform the work across parallel processes. If it is enabled, a process will be launched for each group specified by the Group By parameter. Parallel Processing LevelsFor example, on a quad-core machine, minimal parallelism will result in two simultaneous FME processes. Extreme parallelism on an 8-core machine would result in 16 simultaneous processes. You can experiment with this feature and view the information in the Windows Task Manager and the Workbench Log window. |
Input Ordered |
No: This is the default behavior. Processing will only occur in this transformer once all input is present. By Group: This transformer will process input groups in order. Changes of the value of the Group By parameter on the input stream will trigger batch processing on the currently accumulating group. This will improve overall speed if groups are large/complex, but could cause undesired behavior if input groups are not truly ordered. Specifically, on a two input-port transformer, "in order" means that an entire group must reach both ports before the next group reaches either port, for the transformer to work as expected. This may take careful consideration in a workspace, and should not be confused with both port's input streams being ordered individually, but not synchronously. ![]() Using Ordered input can provide performance gains in some scenarios, however, it is not always preferable, or even possible. Consider the following when using it, with both one- and two-input transformers. Single Datasets/Feature Types: Are generally the optimal candidates for Ordered processing. If you know that the dataset is correctly ordered by the Group By attribute, using Input is Ordered By can improve performance, depending on the size and complexity of the data. If the input is coming from a database, using ORDER BY in a SQL statement to have the database pre-order the data can be an extremely effective way to improve performance. Consider using a Database Readers with a SQL statement, or the SQLCreator transformer. Multiple Datasets/Feature Types: Since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group, using Ordering with multiple feature types is more complicated than processing a single feature type. Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order. One approach is to send all features through a Sorter, sorting on the expected Group By attribute. The Sorter is a feature-holding transformer, collecting all input features, performing the sort, and then releasing them all. They can then be sent through an appropriate filter (TestFilter, AttributeFilter, GeometryFilter, or others), which are not feature-holding, and will release the features one at a time to the transformer using Input is Ordered By, now in the expected order. The processing overhead of sorting and filtering may negate the performance gains you will get from using Input is Ordered By. In this case, using Group By without using Input is Ordered By may be the equivalent and simpler approach. In all cases when using Input is Ordered By, if you are not sure that the incoming features are properly ordered, they should be sorted (if a single feature type), or sorted and then filtered (for more than one feature or geometry type). As with many scenarios, testing different approaches in your workspace with your data is the only definitive way to identify performance gains. |
Overlap Count Attribute | The Overlap Count Attribute added to output point features holds the number of area features that they were inside of. The Overlap Count Attribute added to output area features holds the number of point features that they contained. |
Areas First |
If Areas First is set to Yes, then the PointOnAreaOverlayer assumes that all Area features will enter the transformer before any Point features. This can reduce memory use of the PointOnAreaOverlayer if you have many Point features to overlay. Any further Area features that arrive after the first Point feature will be logged with a warning and discarded. If the Input Ordered parameter is set to By Group, the Area First requirement applies to each group separately. This means that the Area and Point features from the first group must enter the transformer before the Area and Point features from the second group. |
Aggregate Handling |
Choose how aggregate geometries are to be handled. Deaggregate: Decompose aggregates into their individual components. Reject: Do not process aggregates and output them via the <Rejected> port. |
If attributes on the incoming and original feature share the same name, but are not geometry attributes that start with fme_, then they are deemed conflicted.
Accumulation Mode |
Merge Incoming: The original feature will retain all of its own un-conflicted attributes, and will additionally acquire any un-conflicted attributes that the incoming feature has. This mode will handle conflicted attributes based on the Conflict Resolution parameter. Prefix Incoming: The original feature will retain all of its own attributes. In addition, the original will acquire attributes reflecting the incoming feature’s attributes, with the name prefixed with the Prefix parameter. Only Use Incoming: The original feature will have all of its attributes removed, except geometry attributes that start with fme_. Then, all of the attributes from one (arbitrary) incoming feature will be placed onto the original. |
Conflict Resolution |
Use Original: If a conflict occurs, the original values will be maintained. Use Incoming: If a conflict occurs, the values of the incoming will be transferred onto the original. |
Prefix | If the Accumulation Mode parameter is set to Prefix Incoming, this value will prefix attributes that are being added to the original feature from the incoming feature. |
Generate List on Output ‘Point’
When enabled, adds a list attribute to the Point output features, and the attributes of each area containing an output point are added to that point's list.
Note that no intersections between area features are computed.
‘Point’ List Name |
Enter a name for the list attribute. Note: List attributes are not accessible from the output schema in Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. All list attribute transformers are displayed in the Contents pane of the Transformer Help under Lists. Alternatively, AttributeExposer can be used. |
Add To 'Point' List |
All Attributes: All attributes will be added to the output Point features. Selected Attributes: Enables the Selected Attributes parameter, where specific attributes may be chosen for inclusion. |
Selected Attributes | Enabled when Add To 'Point' List is set to Selected Attributes. Specify the attributes you wish to be included. |
When enabled, adds a list attribute to the Area output features, and the attributes of each point contained by an output area are added to that area's list.
‘Area’ List Name |
Add To 'Area' List |
All Attributes: All attributes will be added to the output Area features. Selected Attributes: Enables the Selected Attributes parameter, where specific attributes may be chosen for inclusion. |
Selected Attributes | Enabled when Add To 'Area' List is set to Selected Attributes. Specify the attributes you wish to be included. |
A set of control characters is available in the Text Editor. | |
Working with User Parameters | Create your own editable parameters. |
Yes |
Dependencies | |
FME Licensing Level | FME Professional Edition and above |
Aliases | |
History | |
Categories |
Search for all results about the PointOnAreaOverlayer on the FME Knowledge Center.
