You are here: Attributes > AttributeCopier
AttributeCopier
Copies existing attributes to new attributes with user-specified names. The existing attribute remains intact and a new attribute is created that has a different name, but the same values.
Jump to Configuration
  • Create a copy of an attribute to preserve the original while transforming the copy
  • Create persistent mappings between differing input and output attribute names so that the mapping won’t be lost if a connector is manually removed or replaced.
Blank rows are provided where you can create pairs of input and output attributes. The current values of the input attributes are copied to the output. One or more pairs can be added, and all features that pass through the transformer are modified according to these selections. You can optionally provide default values to be applied to the output where input values are missing.
Dialog Options
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
FME Licensing Level FME Base Edition and above
Aliases
History
Categories
Attributes
FME Knowledge Center
Search for all results about the AttributeCopier on the FME Knowledge Center.
