You are here: Strings > FilenamePartExtractor
Extracts specified parts of a filename path and returns the results as string attributes.
When parsing the path, both backslashes and forward slashes are handled as separators, regardless of operating system.
Example
For example, the path
C:\WINNT\Profiles\user\Desktop\roads.shp
would be extracted as follows:
Folder Path C:\WINNT\Profiles\user\Desktop\
Full Filename roads.shp
Filename Root roads
Filename Extension shp
Folder Name Desktop
Transformer Categories
Strings
Search FME Knowledge Center
