You are here: Workflows > AutodeskA360Connector
Accesses the Autodesk A360 file storage service to upload or download files or list file and folder information from a Autodesk A360 account.
Jump to Configuration
  • Manage datasets on Autodesk A360 by uploading and downloading files
  • Transfer a file's contents (such as XML or raster) into or out of an attribute in FME
  • Read downloaded Autodesk A360 data using the FeatureReader, or upload data written by the FeatureWriter to Autodesk A360
  • Retrieve file and folder names, paths, and other information from Autodesk A360 to use elsewhere in a workspace
The AutodeskA360Connector uses your Autodesk A360 account credentials (either via a previously defined FME web connection, or by setting up new FME web connection right from the transformer) to access the file storage service.
Depending on your choice of actions, it will upload or download files, folders, and attributes or list information from the service. On uploads, a File or Folder ID attribute is added to the output features. On List actions, file/folder information is added as attributes.
  • This transformer cannot be used to directly move or copy files between different Autodesk A360 locations. However, multiple AutodeskA360Connectors can be used to copy files to a new location.
  • The FeatureReader can access Autodesk A360 directly (without using the AutodeskA360Connector), however, a local copy of the dataset will not be created.
The remaining parameters available depend on the value of the Autodesk A360 Action parameter. Parameters for each Autodesk A360 Action are detailed below.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Autodesk A360 account
FME Licensing Level FME Professional Edition and above
Aliases
History Released FME 2017.0
Categories
Integrations
Workflows
FME Knowledge Center
Search for all results about the AutodeskA360Connector on the FME Knowledge Center.
