CharacterCodeReplacer
Sets the result attribute to the character whose numeric code was contained in the source code attribute (or the entered integer).
This can be used when the numeric Unicode code of any character (from Basic Multilingual Plane) is available, but the actual Unicode character is desired. For example, if the source attribute had the value 65487 (U+FFCF), a half-width Hangul letter ᅬ character would be placed in the resulting string.
The numeric Unicode code of any character.
The name of the attribute that will store the resulting value.
Transformer Categories
Related Transformers
To obtain the numeric code equivalent of a character, use the CharacterCodeExtractor transformer.
Transformer History
This transformer was previously named CharacterEncoder.
Search FME Knowledge Center
Tags Keywords: CharacterEncoder
