You are here: Workflows > GeometryExtractor
GeometryExtractor
Extracts the geometry of a feature according to the setting of the geometry encoding parameter.
The resulting encoded geometry is added to the feature in an attribute. This attribute can later be restored as the feature's geometry via the GeometryReplacer transformer.
This transformer is often used to make a copy of the feature's geometry into an attribute before some temporary geometry change is made, so that it can later be restored.  Alternately, the geometry may be extracted to be stored in a database or other file format that cannot handle geometry, but can handle large attributes as blobs or text strings.  Later, FME can read this data back and restore the geometry via the GeometryReplacer transformer.
Encoded Polyline Parameters
Geohash Parameters
GML/KML Parameters
OGC Parameters
MGRS Parameters
MS SQL Server Parameters
ISO 6709 Geographic Point Parameters
GeometryExtractor does not perform any repairs to feature geometries during extraction. Geometries are extracted in their current state.
To carry out a similar operation on raster data, please use the RasterExtractor transformer. For point cloud data, please use the PointCloudExtractor.
Be sure to position this transformer as close as possible to where the geometry attribute is being used. Positioning the transformer too early can cause unnecessary use of system resources.
Transformer Categories
Calculated Values
Geometries
Format Specific
Workflows
Related Transformers
GeometryReplacer
RasterExtractor
RasterReplacer
PointCloudExtractor
PointCloudReplacer
FME Licensing Level
Transformer History
This transformer contains the functionality of the now-deprecated OGCGeometryExtractor and XMLGeometryExtractor.
Technical History
Associated FME function or factory: @Geometry, @OGCGeometry, @JSONGeometry, @GeoRSSGeometry, @GMLGeometry, @KMLGeometry
Search FME Knowledge Center
