You are here: Workflows > PinterestConnector
PinterestConnector
Accesses the Pinterest social network service to create, edit, download, or delete Pins and Boards or list Pin/Board information from a Pinterest account.
Jump to Configuration
  • Manage data on Pinterest by creating, downloading, and deleting Pins and Boards
  • Transfer a Pin's contents into or out of an attribute in FME
  • View downloaded Pinterest data using the Data Inspector
  • Retrieve Pin and Board names, paths, links and other information from Pinterest to use elsewhere in a workspace
The PinterestConnector uses your Pinterest account credentials (either via a previously defined FME web connection, or by setting up new FME web connection right from the transformer) to access the social network.
Depending on your choice of actions, it will create, edit or download Pins, Boards, and features; list information from the service; or delete items from the service. On create and edit, link attributes can be added to the output features. On List and Download actions, links and Pin/Board information are added as attributes.
  • This transformer can only create a Pin using .png, .jpg, or.gif images.
The remaining parameters available depend on the value of the Request > Pinterest Action parameter. Parameters for each Pinterest Action are detailed below.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Pinterest account
FME Licensing Level FME Professional Edition and above
Aliases
History Released FME 2018.0
Categories
Integrations
Workflows
FME Knowledge Center
Search for all results about the PinterestConnector on the FME Knowledge Center.
