You are here: Strings > AttributeValueMapper
Looks up and assigns attribute values based on other attributes, and stores the looked-up value in a new attribute.
This transformer does not modify feature types.
Attribute Selection
Mapping Parameters
Value Map
Additional Value Settings
This section contains documentation common to Default Value, Source Value, and Destination Value.
Example
This example maps the values "Non-Residential" and "Residential" of the type attribute to a new attribute, category, with values "N" and "R", respectively.
Transformer Categories
Strings
Transformer History
This transformer was previously named the ValueMapper.
Search FME Knowledge Center
Tags Keywords: ValueMapper
