You are here: Spatial Analysis > AnchoredSnapper
AnchoredSnapper
Takes a series of features that match the input specification and performs snapping on the features that lie within the specified tolerance from other features that match the input specification. You can use this transformer to perform cleaning operations on data during a translation.
The difference between the AnchoredSnapper and the Snapper is that anchor features are considered to be accurate and consequently do not move.
Transformer
  • Any feature that undergoes dimensional collapse as a result of being snapped will be logged as "degenerate" and dropped. "Dimensional collapse" refers to a line or area that becomes a point, or an area that becomes a line.
  • A short cleanup step is performed after snapping. This step will remove duplicate points, and may create aggregates to preserve overlapping, directed segments.
Example
FME Licensing Level
FME Professional Edition and above
Transformer Categories
Geometries
Spatial Analysis
Search FME Knowledge Center
Tags Keywords: FixedSnapper BaseSnapper
