SQLCreator
Generates FME features from the results of a SQL query against a database. One FME feature is created for each row of the results of the SQL Query.
Relationship to FeatureMerger
The FeatureMerger joins two datasets and uses a simple, single attribute key to match features. The FeatureMerger is also able to perform certain geometric operations on incoming features using its Merge Type parameter.
Relationship to InlineQuerier
If all the data to be queried already exists in a SQL-capable data source, it is always more efficient to use the SQLCreator or SQLExecutor, because this allows the queries and filtering of the data to be executed directly by the database before it enters the FME environment.
Relationship to DatabaseJoiner
The DatabaseJoiner is very useful and efficient when there exists a one-to-one or one-to-many relationship between data flowing through FME and data held within a database. If it can be used, the DatabaseJoiner can be more efficient than using either the InlineQuerier or SQLCreator/SQLExecutor, provided that the DatabaseJoiner key fields have indexes in the source database. The DatabaseJoiner is simple to use and does not require any knowledge of SQL.
Example
Transformer Categories
Search FME Knowledge Center
