You are here: Workflows > FMEServerJobSubmitter
Submits FME jobs to be run on an FME Server. A job consists of a workspace (housed within a repository on an FME Server) together with values for each of its published parameters. This transformer submits one job per feature which enters it. Any published parameters of the server workspace will be given values as specified in the transformer, or taken from attributes of the feature which enters it.
Dependencies
This transformer requires an FME Server connection.
Connection
You can connect to an FME Server in one of the following ways:
Note: You can click the Status hyperlink to ensure that the FME Server connection has been successfully established.
Submission Mode
Job Parameters
Advanced
Transformer Categories
Integrations
Web
Workflows
FME Licensing Level
Transformer History
This transformer was previously named the ServerJobSubmitter.
Search FME Knowledge Center
Tags Keywords: ServerJobSubmitter
