FME Transformers: 2025.2
Categories
Rasters
Related Transformers
AttributeFileWriter
GeometryExtractor
GeometryRemover
GeometryReplacer
PointCloudExtractor
PointCloudReplacer
RasterReplacer
RasterExtractor
Serializes the geometry of a raster feature into a Blob attribute, encoding the contents according to a choice of common binary raster formats.
Jump to Configuration
  • Storing rasters in databases that do not support specific raster types but do support Blobs.
  • Storing a raster as an attribute of a feature, such as attaching images to vector features.
The RasterExtractor receives raster features and puts a copy of the raster geometry into an attribute, as a Blob - a Binary Large OBject.
The Blob content may be encoded as a variety of common raster formats. The name of the chosen format will also be recorded in an attribute for reference when decoding.
There are no parameters in the transformer to control how the raster is formatted, and encoding is done based on default settings for the chosen format. If necessary, format-specific settings may be overwritten by setting format attributes on the raster feature, prior using the RasterExtractor. For example, if encoding to JPEG, the compression level could be set via the jpeg_compression_level format attribute. Consult the appropriate format’s Writer documentation for a complete list of available attributes.
  • This transformer may be used for writing raster data to a database field. Note that when writing the Raster Blob Attribute, you may need to adjust the attribute type to an unbounded data type to avoid truncation of the data. Choose an appropriate attribute type depending on the destination format (for example, an appropriate attribute type for SQL Server is 'image').
  • The RasterReplacer may be used to perform the reverse operation and convert the encoded blob back to the original raster geometry.
  • Different encoding formats may carry through different information. For example, GeoTIFF preserves coordinate system and extents, whereas PNG does not.
  • To carry out a similar operation on vector data, use the GeometryExtractor transformer. For point cloud data, use the PointCloudExtractor.
  • To remove the original geometry after using a RasterExtractor (leaving only the Blob attribute version), use a GeometryRemover.
  • The AttributeFileWriter transformer can be used to write the Raster Blob Attribute directly to a file.
Choosing a Raster Transformer
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the RasterExtractor on the FME Community.
