FME Transformers: 2025.2
Categories
Rasters
Related Transformers
RasterPyramider
RasterSubsetter
RasterTiler
WebMapTiler
RasterResampler
Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, by interpolating new cell values.
Jump to Configuration
  • Reducing raster resolution (by reducing the number of cells and increasing cell size)
  • Coercing a raster to specific dimensions or cell (pixel) size for further processing purposes or to match other data
  • Creating thumbnail images of rasters
The RasterResampler accepts raster features and alters the number of rows/columns and resizes cell (pixel) size according to the parameter selections. One raster feature is output for each input feature.
Output raster resolution may be specified by set dimensions (columns and rows), cell size in ground units, or percentage of original resolution.
A variety of methods are available for output cell value interpolation.
A: Original resolution
B: Desired resolution
C: Desired resolution compared to original
D: Resampled output raster
  • To resize rasters (clipping or padding) without changing the cell size, consider using the RasterSubsetter
  • To resample rasters to multiple sizes, consider using the WebMapTiler or the RasterPyramider.
  • To split rasters in multiple smaller rasters without changing the cell size, consider using the RasterTiler.
  • Although this transformer can be used to increase raster resolution, usually there is little benefit in doing so (with an exception being to match the resolution of other raster data for processing purposes).
Choosing a Raster Transformer
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the RasterResampler on the FME Community.
