FME Transformers: 2025.2
Categories
Rasters
Related Transformers
RasterBandAdder
RasterBandCombiner
RasterBandKeeper
RasterBandOrderer
RasterBandRemover
RasterBandSeparator
Separates bands or unique band and palette combinations, and outputs either individual raster features or a single new raster feature containing all combinations.
Jump to Configuration
  • Isolating bands or palettes to meet format or processing requirements.
The RasterBandSeparator receives raster features and separates their bands and palettes into individual output raster features.
Raster features may be split by band, band and palette, or palette.
Separating by Band Only will produce multiple output features, one for each band.
Separating by Band and Palette will also produce multiple output features, one for every unique band and palette combination.
Separating by Palette Only will produce a single output feature per input feature, containing bands for every unique band and palette combination.
Attributes may be created to record which raster, band, and/or palette from which the output feature originated.
The order of the input features and their bands and palettes will determine the order of the output features. A Sorter transformer may be used to set the order in which the features are processed.
Choosing a Raster Transformer
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases RasterBandSplitter RasterSplitter
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the RasterBandSeparator on the FME Community.
