FME Transformers: 2025.2
Categories
Rasters
Related Transformers
AttributeRangeFilter
AttributeRangeMapper
Dissolver
RasterCellCoercer
RasterToPolygonCoercer
Creates polygons from input raster features. One polygon is output for each contiguous area of cells with the same value in all bands.
Jump to Configuration
  • Converting raster images to a set of polygons.
  • Vectorizing raster data for vector geoprocessing.
The RasterToPolygonCoercer accepts raster input features. Polygons are traced around the edges of cells (pixels), enclosing areas with identical band values. Donuts are created where contiguous areas contains islands of differing values.
Nodata cells may either be included or excluded.
Output polygons may retain the raster’s attributes, and may also have a new Label Attribute added, containing the band values represented as a comma-separated list.
This transformer supports raster band selection. The RasterSelector can be used to modify selection.
  • If memory usage becomes an issue while using this transformer, try adding a RasterCheckpointer before the RasterToPolygonCoercer.
  • If you need a polygon for each pixel in the raster, consider using the RasterCellCoercer.
Choosing a Raster Transformer
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the RasterToPolygonCoercer on the FME Community.
