FME Transformers: 2026.2
Categories
Rasters
Related Transformers
Clipper
RasterTiler
WebMapTiler
RasterSubsetter
Clips raster features using pixel bounds instead of ground coordinates, and optionally adds cells around the perimeter.
Jump to Configuration
  • Clipping a portion of a raster based on number of pixels instead of ground coordinates
  • Adding a frame of empty cells around a raster or subset of a raster
The RasterSubsetter accepts raster features, and clips them according to the origin and number of pixels defined.
The subset is defined by a starting column and row, and the number of columns and rows (that is, cells) to be included.
The starting column and row position are offset from the raster origin (0,0), in the upper left corner of the raster. For more information on raster structure, see Raster.
The clipped raster (subset) may be padded with empty cells, with settings available for top, bottom, left and right.
  • To superset a raster, set the Subset to include the entire raster and add Padding.
  • To clip a raster by spatial extents, use the Clipper.
Choosing a Raster Transformer
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the RasterSubsetter on the FME Community.
