FME Transformers: 2026.2
Categories
Filters and Joins
Rasters
Related Transformers
RasterConvolver
RasterGeoreferencer
RasterPyramider
RasterResampler
RasterRotationApplier
RasterSelector
RasterSubsetter
RasterTiler
WebMapTiler
RasterMosaicker
Merges multiple raster features into a single raster feature.
Jump to Configuration
  • Merging multiple rasters
  • Joining abutting raster tiles together into a single feature
  • Merging overlapping raster features together, blending the overlaps
  • Preparing data for use in operations that require a single raster feature (eg VectorOnRasterOverlayer)
The RasterMosaicker accepts a number of raster features and combines them into a single raster feature.
The input rasters must all have the same number of bands and palettes, or selected bands and palettes.
Each band is individually mosaicked together, and then appended to the output raster. The output raster will have the same number of bands and palettes as the input (whether whole rasters or selected bands/palettes).
If there are gaps in data (that is, areas not covered by any raster), the empty cells will be filled with Nodata values if available, or zero if not.
Bands and Palettes
Rasters may have one band or multiple bands.
Rasters may have no palette, one palette, or multiple palettes. For more information on raster structure, see Raster.
Selecting Raster Bands and Palettes
To select specific bands and/or palettes, use the RasterSelector prior to the RasterMosaicker.
  • When there are no selected palettes or Merge Palettes is No, each band in a set must have the same band interpretation and Nodata value.
  • When there are selected palettes and Merge Palettes is Yes, each band must have one selected palette, and all palettes must have the same value interpretation.
A variety of options are available for handling alignment issues, overlapping pixel values, Nodata values, and differing resolution.
Attributes from the input features may be merged onto the output raster, and an optional Count attribute will record the number of input features included.
Attributes from the input features may also be appended to an optional list attribute.
Choosing a Raster Transformer
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the RasterMosaicker on the FME Community.
