FME Transformers: 2026.2
Categories
Coordinates
Rasters
Related Transformers
Affiner
RasterGCPExtractor
RasterGeoreferencer
RasterGCPSetter
Sets Ground Control Points (GCPs) on a raster, pairing cell positions with known coordinates.
Jump to Configuration
  • Specifying georeferencing information for rasters such as scanned maps, surveys, and uncorrected aerial images, based on known positions in the source dataset.
The RasterGCPSetter receives raster features and attaches specified Ground Control Points (GCPs) to them as a raster property.
Each GCP is composed of a pair of positions - the first being a row and column number within the raster, and the second being a known position on the ground, described by a Coordinate System and a set of x,y,z coordinates.
Multiple GCPs may be set with one RasterGCPSetter, and must all be the same coordinate system.
The RasterGCPSetter does not georeference rasters - it only attaches properties that may be used to do so. The GCPs must be applied to the raster to carry out the georeferencing.
A minimum of three GCPs are generally required to georeference a raster. If the raster has already set GCPs, the old GCPs will be overwritten, and so all GCPs must be set in one RasterGCPSetter.
GCP Format
Each GCP has five components, separated by spaces:
Column Row X-Coordinate Y-Coordinate Z-Coordinate
For example:
1442 6863 483000 5456000 0
Multiple GCPs are combined into one string, separated by semicolons:
1442 6863 483000 5456000 0;1415 1143 483000 5468000 0;4754 1120 490000 5468000 0
  • To apply GCPs to a raster in FME, you may use the Apply GCPs parameter in raster format Readers that support GCPs. A RasterGCPApplier custom transformer is also available on the FME Hub.
  • To extract GCP values from a raster, use the RasterGCPExtractor.
Choosing a Raster Transformer
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the RasterGCPSetter on the FME Community.
