FME Transformers: 2026.2
Categories
Calculated Values
Rasters
Related Transformers
RasterCellValueCalculator
RasterCellValueReplacer
RasterCellValueRounder
RasterConvolver
RasterExpressionEvaluator
RasterSingularCellValueCalculator
RasterStatisticsCalculator
Calculates statistics on raster bands and adds the results as attributes.
Jump to Configuration
The RasterStatisticsCalculator receives raster features and calculates selected statistics on them individually. The results are output on each raster, and may be generated for Band, Palette, or both.
Available statistics include:
  • Minimum
  • Maximum
  • Mean
  • Sum
  • Range
  • Standard Deviation
  • Median
  • Mode
Band statistics are stored as attributes, named <band>.<statisticname>.
Palette statistics are calculated on resolved palette values, and are stored as list attributes, named <band>.<palette>.<statisticname>.
For both types of attribute, <statisticname> will be one of the following: min, max, range, mean, stdev, sum, median, mode.
For multi-band rasters, any additional bands beyond Band 0 must be explicitly specified for inclusion in the parameters dialog - Statistics to Calculate table, under Band Index.
To calculate raster statistics on a group of rasters as a single entity, merge them prior to this transformer with the RasterBandCombiner or RasterMosaicker.
Choosing a Raster Transformer
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the RasterStatisticsCalculator on the FME Community.
