Calculates the slope (maximum rate of change in z) for each cell of a raster.
The RasterSlopeCalculator receives raster features, and calculates the slope for each cell.
Slope may be measured in either Degrees (0 to 90), or Percent Rise (0 to infinity). The calculation is done based on the values of surrounding cells (using a 3 cell x 3 cell window), and a choice of algorithms is available. Cells without data (nodata) may be interpolated for calculation purposes.
Slope values are output on the same band they were calculated from, and the band is converted to Real64.
For multi-band rasters, each band is processed separately, with slope values calculated for each band on each cell. To restrict operation to specific band(s), use a RasterSelector prior to the RasterSlopeCalculator.
This transformer supports raster band selection. The RasterSelector can be used to modify this selection.
Z Factor, Scaling and Units
Input rasters’ horizontal (x and y) units are expected to be the same as vertical (z) units.
If this is not the case - for example, if the horizontal units are in meters with elevation (z) in feet (or any other similar unit type mismatch), you may apply a scale factor (also known as Z Factor) with the Scaler transformer prior to using a RasterSlopeCalculator.
In this example (ground units are meters, elevations are feet), the scale factor to use is 0.3048 - the number of meters in one foot.
If the ground units are lat/long, the appropriate scale factor will vary greatly between the equator and the poles. In this case, consider reprojecting the input raster with a Reprojector, to an appropriate coordinate system with ground units matching the vertical (z) units.
In this example we will perform a slope calculation on a Digital Elevation Model. The source data ranges in elevation from sea level (0) to around 1500 meters, in a mountainous area. Note that elevation is stored in Band 0, as an integer.
Note: This format, CDED, is in an LL83-SECONDS coordinate system - and so the lat/long horizontal (ground) units do not match the vertical (elevation) units in meters.
The DEM is routed first into a Reprojector, where it is converted to UTM83-10, an appropriate local coordinate system with ground units in meters, matching the elevation value units. Then it is routed into a RasterSlopeCalculator.
In the parameters dialog, we select an Output Measurement of Degrees, and use the Horn algorithm. Interpolate Nodata is set to Yes.
The output raster feature has new Band 0 values - the calculated slope - and the band has been converted to a floating point decimal interpretation type (real64).
Note the shape of the output raster compared to the original DEM data - a result of the reprojection.
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
RasterCellOriginSetter | Sets the cell origin point within cells in a raster. |
RasterConvolver |
RasterExpressionEvaluator | Evaluates expressions on each cell in a raster or pair of rasters, including algebraic operations and conditional statements. |
RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering either the extents of a raster or the extent of data within a raster. |
RasterGCPExtractor | Extracts Ground Control Point (GCP) coordinate system and point values from a raster feature and exposes them as attributes. |
RasterGCPSetter | Sets Ground Control Points (GCPs) on a raster, pairing cell positions with known coordinates. |
RasterGeoreferencer | Georeferences a raster by either known corner coordinates or origin, cell size, and rotation. |
RasterHillshader | Generates a grayscale shaded relief representation of terrain, based on elevation values. |
RasterInterpretationCoercer |
RasterMosaicker | Merges multiple raster features into a single raster feature. |
RasterPropertyExtractor | Extracts the geometry properties of a raster feature and exposes them as attributes. |
RasterPyramider | Resamples rasters to multiple resolutions, based on either number of levels or dimensions of the smallest output raster. |
RasterResampler | Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, and interpolates new cell values. |
RasterRotationApplier |
RasterSubsetter | Clips raster features using pixel bounds instead of ground coordinates, and optionally adds cells around the perimeter. |
RasterTiler | Splits each input raster into a series of tiles by specifying either a tile size in cells/pixels or the number of tiles. |
RasterToPolygonCoercer | Creates polygons from input raster features. One polygon is output for each contiguous area of pixels with the same value in the input raster. |
WebMapTiler | Creates a series of image tiles that can be utilized by web mapping applications such as Bing™ Maps, Google Maps™, or Web Map Tile Service. This is done by resampling rasters to various different resolutions and then splitting them into tiles. |
RasterBandAdder | Adds a new band to a raster feature. |
RasterBandCombiner | Merges coincidental raster features into a single output raster feature, preserving and appending all bands. |
RasterBandInterpretationCoercer |
RasterBandKeeper |
RasterBandMinMaxExtractor | Extracts the minimum and maximum band values, palette keys, and palette values from a raster feature, and adds them to a list attribute. |
RasterBandNameSetter | Sets the band name of selected bands on a raster, making raster contents simpler to understand compared to band numbers. |
RasterBandNodataRemover | Removes the existing nodata identifier from selected bands of a raster feature. Any values previously equal to the nodata value are considered valid data. |
RasterBandNodataSetter | Sets a new nodata value on selected bands of a raster feature. |
RasterBandOrderer | Specifies the required order of bands in a raster. Bands are reordered according to the input band indices. |
RasterBandPropertyExtractor | Extracts the band and palette properties of a raster feature and exposes them as attributes. |
RasterBandRemover | Removes any selected bands from a raster feature. |
RasterBandSeparator | Separates bands or unique band and palette combinations, and outputs either individual raster features or a single new raster feature containing all combinations. |
RasterStatisticsCalculator | Calculates statistics on raster bands and adds the results as attributes. |
RasterAspectCalculator |
RasterCellCoercer | Creates individual points or polygons for each cell in a raster, optionally extracting band values as z coordinates or attributes. |
RasterCellValueCalculator | Evaluates basic arithmetic , minimum, maximum or average operations on the cell values of a pair of rasters. |
RasterCellValueReplacer | Replaces a range of band values in a raster with a new single value. |
RasterCellValueRounder | Rounds off raster cell values. |
RasterSingularCellValueCalculator | Performs basic arithmetic operations on the cell values of a raster against a numeric value. |
RasterSlopeCalculator | Calculates the slope (maximum rate of change in z) for each cell of a raster. |
RasterPaletteAdder |
RasterPaletteExtractor | Creates a string representation of an existing palette on a raster and saves it to an attribute. |
RasterPaletteGenerator | Generates a palette out of the selected band(s) of a raster. The output raster will have the selected band(s) replaced by a new band with a palette. |
RasterPaletteInterpretationCoercer |
RasterPaletteNodataSetter |
RasterPaletteRemover | Removes selected palette(s) from raster features. |
RasterPaletteResolver | Resolves the palette(s) on a raster by replacing cell values with their corresponding palette values. Palette values with multiple components, such as RGB, are broken down and the individual values assigned to multiple, newly-added bands. |
RasterCheckpointer | Forces accumulated raster operations to be processed, saving the state to disk and releasing resources to tune performance or assist with memory limitations. |
RasterConsumer | Reads raster features for testing purposes, including any accumulated raster operations. No additional operations are performed, and nothing is done with the features. |
RasterExtractor | Serializes the geometry of a raster feature into a Blob attribute, encoding the contents according to a choice of common binary raster formats. |
RasterNumericCreator | Creates a numeric raster of specified size and resolution, with default cell values. |
RasterReplacer | Decodes a binary attribute containing encoded rasters stored as Blobs, replacing the feature’s geometry with the decoded raster. |
RasterRGBCreator | Creates a color raster feature of specified size, resolution, and interpretation type, with default cell values. |
RasterSelector |
ImageRasterizer | Creates a raster representation of vector or point cloud input features, using the fme_color attribute over a solid background fill for vector features. Point clouds may be rendered using their color or intensity components. |
NumericRasterizer | Creates a numeric raster representation of vector or point cloud input features, where cell values are taken from the z coordinates of the input features and overlaid on a uniform background. |
MapnikRasterizer | Generates a raster from input vector and raster features, with fine control over symbolization and labeling, using the Mapnik toolkit. |
PointOnRasterValueExtractor | Extracts the band and palette values from a raster at the location of one or more input points and sets them as attributes on the feature. |
RasterDEMGenerator | Produces a raster digital elevation model (DEM) by uniformly sampling a Delaunay triangulation generated from input points and breaklines. |
VectorOnRasterOverlayer | Rasterizes vector or point cloud features onto an existing raster. For vector features the fme_color attribute sets pixel color, and point clouds may be rendered using their color or intensity components. |
Raster features with cells to calculate slope values on. Horizontal (x and y) units should be the same as vertical (z) units.
Raster features with calculated slope values, stored in the same band they were provided in, converted to interpretation type real64.
INVALID_RASTER_CANNOT_CALCULATE_SLOPE
Output Measurement |
Select the measurement units of the output slope data. Degrees: Slope will be calculated in degrees. Values will range from 0 (flat) to 90 (vertical). Percent Rise: Slope will be calculated as percent rise. Values will range from 0 (flat) to infinity (vertical). A flat surface will have a slope of 0 percent, a 45 degree surface will have a slope of 100 percent, and as the surface becomes more vertical the slope gets progressively larger. |
Interpolate Nodata |
Calculate values at raster edges and near nodata values. No: When any pixel in the 3x3 window used to calculate the slope value is equal to nodata, the output pixel will also be set to nodata. If the input band does not have a nodata value, the output band nodata value will be set to -1. There will be a one pixel border around the edge of the raster set to the nodata value. Yes: Values around the edge and near nodata values will be estimated by interpolating missing values. Note that holes will not be filled in - cells that are nodata in the input raster will remain nodata in the output. |
Algorithm | The algorithm used to calculate the slope. Some analyses have suggested that Horn's formula is better suited to rougher terrain, whereas Zevenbergen & Thorne's formula is better for smooth terrain. |
A set of control characters is available in the Text Editor. | |
Working with User Parameters | Create your own editable parameters. |
Dependencies | None |
FME Licensing Level | FME Professional Edition and above |
Aliases | |
History | |
Categories |
Search for all results about the RasterSlopeCalculator on the FME Community.
