RasterPaletteNodataSetter
Identifies the palette key that matches a raster band’s nodata value, and sets a value on it.
Jump to Configuration
The RasterPaletteNodataSetter receives raster features and sets a specified value on the palette key that matches the selected band’s nodata value. That is, if the nodata value is zero (0), it will find the palette entry with a key of zero (0) and change that entry’s value.
The raster band must have a nodata value already set, and have a palette.
RGB, RGBA, and string palettes are supported.
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
FME Licensing Level FME Professional Edition and above
Aliases
History
Categories
Rasters
Search for all results about the RasterPaletteNodataSetter on the FME Community.
