RasterBandMinMaxExtractor
Extracts the minimum and maximum band values, palette keys, and palette values from a raster feature, and adds them to a list attribute.
Jump to Configuration
The RasterBandMinMaxExtractor receives raster features, and extracts each raster’s minimum and maximum band values.
If the raster has palettes, the palette key and palette values are also determined. The minimum and maximum palette values are determined from the maximum possible extent of palette values, regardless of whether all values are used in the raster data itself. String palettes are evaluated alphanumerically.
The values are added to list attributes on the output raster feature. Possible list attributes include:
Minimum Band Value _band{}.min
Maximum Band Value _band{}.max
Minimum Palette Key _band{}.palette{}.keyMin
Maximum Palette Key _band{}.palette{}.keyMax
Minimum Palette Value _band{}.palette{}.valueMin
Maximum Palette Value _band{}.palette{}.valueMax
Any nodata values that are present on the band are ignored in the minimum and maximum value calculations.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
FME Licensing Level FME Professional Edition and above
Aliases
History
Categories
Calculated Values
Rasters
Search for all results about the RasterBandMinMaxExtractor on the FME Community.
