ExtExtracts the band and palette values from a raster at the location of one or more input points and sets them as attributes on the feature.
The PointOnRasterValueExtractor receives two sets of input features, Raster and Point, which must be in the same coordinate system. Only one raster may be used per group.
At each point’s position, values are interpolated for the corresponding point on the raster for each band and/or palette. A variety of interpolation methods are available. The interpolated values are added to a new list attribute, named _band{}.value and _band{}.palette{}.value, respectively.
Point features are output with the new list attribute, and rasters are discarded.
No attributes will be set for points outside the raster extents.
This transformer supports raster band selection. The RasterSelector can be used to modify this selection.
In this example, we will extract elevations from a DEM raster (in GEOTIFF format) for the points in a street intersections dataset. The points are shown here, overlaid on the raster. Note that one cell in the raster is selected and Band 0 contains the elevation value.
Both datasets are routed into a PointOnRasterValueExtractor.
In the parameters dialog, the default Interpolation Type of Nearest Neighbor is kept.
Point features are output with elevation values attached as a new list attribute, based on the Nearest Neighbor interpolation. This means the nearest cell center to the point feature provides the new attribute value. As the original raster has only one band, only one value is contained in the list.
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
| RasterConvolver |
| RasterRotationApplier |
| RasterBandKeeper |
| RasterAspectCalculator |
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
| RasterSelector |
Raster from which values will be extracted. Unless Group By is being used, only one raster will be accepted. Both Raster and Point input should be in the same coordinate system.
Point features to overlay on the Raster input. Both Raster and Point input should be in the same coordinate system.
Point features with interpolated raster values attached as a list attribute.
| Group By |
The points may be organized into groups with the Group By parameter, with each group of points having its own reference raster. |
| Group By Mode |
| Interpolation Type |
Select an interpolation method for determining raster values:
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
Yes |
| Aliases | PointOnRasterOverlayer |
| History | This transformer was previously named PointOnRasterOverlayer. |
| Categories |
Search for all results about the PointOnRasterValueExtractor on the FME Community.
