The RasterPyramider accepts raster features, and “pyramids” them - resampling them to produce a set of output rasters at varying resolutions, appropriate for different zoom levels.
The number of rasters produced may be specified by Number of Levels, or by defining the smallest level size by number of columns and rows in cells (pixels).
Various methods are available for interpolation of pixel values during resampling.
Attributes may be added to the output tiles to record Pyramid level, original raster index, and number of levels produced.
This transformer is unaffected by raster band and/or palette selection.
In this example, we will create pyramids for an orthophoto. The source image is 1 meter resolution, at 1600 by 1000 pixels. Note the Min and Max Extents - these will remain unchanged as the image is resampled.
The raster is routed into a RasterPyramider.
In the parameters dialog, we select Number of Levels as the method, and set that number to 4.
Force Level Sizes to be Powers of Two is set to Yes - this will force raster dimensions to the commonly-used progression of powers of two - see Parameters below for more details on how this works.
Five raster features are output - the original, which is Level 0, plus four new pyramided rasters.
Pyramid Level 1
Pyramid Level 1 is the closest to the original raster, with new dimensions, 1024 by 512, according to the Powers of Two parameter.
Note that the geographic extents are the same as the original - but the pixel size (spacing) and resolution have changed.
Pyramid Level 4
At Pyramid Level 4, the geographic extents are still the same but the raster itself is much smaller at 128 by 64 pixels.
A closer look at the bridge detail clearly illustrates the results of resampling for different levels.
Note on Powers of Two
Using the Powers of Two parameter will produce raster dimensions with common and useful numbers for display purposes. However, if the source raster’s dimensions are not originally a power of two, as may often be the case, pyramiding using powers of two will produce pixels that are not square in ground units.
In this example, the source image pixels are 1 meter square (Spacing 1,1). At pyramid level 1, the spacing (pixel size in ground units) becomes 1.5625, 1.93125. The difference in the width and height of the pixel is a result of finding the nearest power of two numbers to scale vertically and horizontally - that is, interpolating 1600 x 1000 to 1024 by 512 within the same geographic extents.
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
RasterCellOriginSetter | Sets the cell origin point within cells in a raster. |
RasterConvolver |
RasterExpressionEvaluator | Evaluates expressions on each cell in a raster or pair of rasters, including algebraic operations and conditional statements. |
RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering either the extents of a raster or the extent of data within a raster. |
RasterGCPExtractor | Extracts Ground Control Point (GCP) coordinate system and point values from a raster feature and exposes them as attributes. |
RasterGCPSetter | Sets Ground Control Points (GCPs) on a raster, pairing cell positions with known coordinates. |
RasterGeoreferencer | Georeferences a raster by either known corner coordinates or origin, cell size, and rotation. |
RasterHillshader | Generates a grayscale shaded relief representation of terrain, based on elevation values. |
RasterInterpretationCoercer |
RasterMosaicker | Merges multiple raster features into a single raster feature. |
RasterPropertyExtractor | Extracts the geometry properties of a raster feature and exposes them as attributes. |
RasterPyramider | Resamples rasters to multiple resolutions, based on either number of levels or dimensions of the smallest output raster. |
RasterResampler | Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, and interpolates new cell values. |
RasterRotationApplier |
RasterSubsetter | Clips raster features using pixel bounds instead of ground coordinates, and optionally adds cells around the perimeter. |
RasterTiler | Splits each input raster into a series of tiles by specifying either a tile size in cells/pixels or the number of tiles. |
RasterToPolygonCoercer | Creates polygons from input raster features. One polygon is output for each contiguous area of pixels with the same value in the input raster. |
WebMapTiler | Creates a series of image tiles that can be utilized by web mapping applications such as Bing™ Maps, Google Maps™, or Web Map Tile Service. This is done by resampling rasters to various different resolutions and then splitting them into tiles. |
RasterBandAdder | Adds a new band to a raster feature. |
RasterBandCombiner | Merges coincidental raster features into a single output raster feature, preserving and appending all bands. |
RasterBandInterpretationCoercer |
RasterBandKeeper |
RasterBandMinMaxExtractor | Extracts the minimum and maximum band values, palette keys, and palette values from a raster feature, and adds them to a list attribute. |
RasterBandNameSetter | Sets the band name of selected bands on a raster, making raster contents simpler to understand compared to band numbers. |
RasterBandNodataRemover | Removes the existing nodata identifier from selected bands of a raster feature. Any values previously equal to the nodata value are considered valid data. |
RasterBandNodataSetter | Sets a new nodata value on selected bands of a raster feature. |
RasterBandOrderer | Specifies the required order of bands in a raster. Bands are reordered according to the input band indices. |
RasterBandPropertyExtractor | Extracts the band and palette properties of a raster feature and exposes them as attributes. |
RasterBandRemover | Removes any selected bands from a raster feature. |
RasterBandSeparator | Separates bands or unique band and palette combinations, and outputs either individual raster features or a single new raster feature containing all combinations. |
RasterStatisticsCalculator | Calculates statistics on raster bands and adds the results as attributes. |
RasterAspectCalculator |
RasterCellCoercer | Creates individual points or polygons for each cell in a raster, optionally extracting band values as z coordinates or attributes. |
RasterCellValueCalculator | Evaluates basic arithmetic , minimum, maximum or average operations on the cell values of a pair of rasters. |
RasterCellValueReplacer | Replaces a range of band values in a raster with a new single value. |
RasterCellValueRounder | Rounds off raster cell values. |
RasterSingularCellValueCalculator | Performs basic arithmetic operations on the cell values of a raster against a numeric value. |
RasterSlopeCalculator | Calculates the slope (maximum rate of change in z) for each cell of a raster. |
RasterPaletteAdder |
RasterPaletteExtractor | Creates a string representation of an existing palette on a raster and saves it to an attribute. |
RasterPaletteGenerator | Generates a palette out of the selected band(s) of a raster. The output raster will have the selected band(s) replaced by a new band with a palette. |
RasterPaletteInterpretationCoercer |
RasterPaletteNodataSetter |
RasterPaletteRemover | Removes selected palette(s) from raster features. |
RasterPaletteResolver | Resolves the palette(s) on a raster by replacing cell values with their corresponding palette values. Palette values with multiple components, such as RGB, are broken down and the individual values assigned to multiple, newly-added bands. |
RasterCheckpointer | Forces accumulated raster operations to be processed, saving the state to disk and releasing resources to tune performance or assist with memory limitations. |
RasterConsumer | Reads raster features for testing purposes, including any accumulated raster operations. No additional operations are performed, and nothing is done with the features. |
RasterExtractor | Serializes the geometry of a raster feature into a Blob attribute, encoding the contents according to a choice of common binary raster formats. |
RasterNumericCreator | Creates a numeric raster of specified size and resolution, with default cell values. |
RasterReplacer | Decodes a binary attribute containing encoded rasters stored as Blobs, replacing the feature’s geometry with the decoded raster. |
RasterRGBCreator | Creates a color raster feature of specified size, resolution, and interpretation type, with default cell values. |
RasterSelector |
ImageRasterizer | Creates a raster representation of vector or point cloud input features, using the fme_color attribute over a solid background fill for vector features. Point clouds may be rendered using their color or intensity components. |
NumericRasterizer | Creates a numeric raster representation of vector or point cloud input features, where cell values are taken from the z coordinates of the input features and overlaid on a uniform background. |
MapnikRasterizer | Generates a raster from input vector and raster features, with fine control over symbolization and labeling, using the Mapnik toolkit. |
PointOnRasterValueExtractor | Extracts the band and palette values from a raster at the location of one or more input points and sets them as attributes on the feature. |
RasterDEMGenerator | Produces a raster digital elevation model (DEM) by uniformly sampling a Delaunay triangulation generated from input points and breaklines. |
VectorOnRasterOverlayer | Rasterizes vector or point cloud features onto an existing raster. For vector features the fme_color attribute sets pixel color, and point clouds may be rendered using their color or intensity components. |
Original raster features and resampled (pyramided) rasters according to the parameter selections.
INVALID_RASTER_NO_BANDS
Interpolation Type |
Cell values are interpolated in order to change the raster to the specified sizes.
Raster Index Attribute | If a Raster Index Attribute is specified, an attribute will be added to each output feature that identifies which raster it was created from. This index is zero-based, so all pyramid levels created from the first input raster will have a value of 0, all pyramid levels created from the second input raster will have a value of 1, and so on. |
Pyramid Level Attribute |
If a Pyramid Level Attribute is specified, an attribute will be added to each output feature that identifies its level in the pyramid. The input raster is considered to be the base of the pyramid (level 0), so the largest level that is output for a given input raster will have a value of 1, the second largest will have a value of 2, and so on. |
Number of Pyramid Levels Attribute | If a Number of Pyramid Levels Attribute is specified, an attribute will be added to each output raster indicating the number of levels in the pyramid to which it belongs |
A set of control characters is available in the Text Editor. | |
Working with User Parameters | Create your own editable parameters. |
Dependencies | None |
FME Licensing Level | FME Professional Edition and above |
Aliases | |
History | |
Categories |
Search for all results about the RasterPyramider on the FME Community.
