RasterSubsetter
Clips raster features using pixel bounds instead of ground coordinates, and optionally adds cells around the perimeter.
Jump to Configuration
The RasterSubsetter accepts raster features, and clips them according to the origin and number of pixels defined.
The subset is defined by a starting column and row, and the number of columns and rows (that is, cells) to be included.
The starting column and row position are offset from the raster origin (0,0), in the upper left corner of the raster. For more information on raster structure, see Rasters (IFMERaster).
The clipped raster (subset) may be padded with empty cells, with settings available for top, bottom, left and right.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
FME Licensing Level FME Professional Edition and above
Aliases
History
Categories
Rasters
Search for all results about the RasterSubsetter on the FME Community.
