RasterHillshader
Generates a grayscale shaded relief representation of terrain, based on elevation values.
Jump to Configuration
The RasterHillshader receives elevation raster features and creates a shaded relief representation, derived from slope and aspect calculated on the input elevation values.
The input raster’s horizontal and vertical units are expected to be the same.
Input band(s) are converted to GRAY8, with hillshade values between 0 and 255. The position of the light source may be adjusted, and a choice of algorithms is available.
If the input band has a nodata value set, or if Interpolate Nodata is set to No, an ALPHA8 band is also generated, with a cell value of 0 (fully transparent) where the input was nodata and a value of 255 (fully opaque) where the input was data.
Interpolate Nodata means that nodata values will be replaced with actual values, calculated from the neighboring cells. When Interpolate Nodata is set to Yes, there are no nodata cells, and so no alpha band is required.
This transformer supports raster band selection. The RasterSelector can be used to modify this selection.
Z Factor, Scaling and Units
Input rasters’ horizontal (x and y) units are expected to be the same as vertical (z) units.
If this is not the case - for example, if the horizontal units are in meters with elevation (z) in feet (or any other similar unit type mismatch), you may apply a scale factor (also known as Z Factor) with the Scaler transformer prior to using a RasterHillshader.
In that example (ground units are meters, elevations are feet), the scale factor to use is 0.3048 - the number of meters in one foot.
If the ground units are decimal degrees (lat/long), the appropriate scale factor will vary greatly between the equator and the poles. In this case, consider reprojecting the input raster with a Reprojector, to an appropriate coordinate system with ground units matching the vertical (z) units.
If units are mismatched, the transformer may complete processing, but will produce incorrect or unexpected results.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
FME Licensing Level FME Professional Edition and above
Aliases
History
Categories
3D
Cartography and Reports
Rasters
Search for all results about the RasterInterpretationCoercer on the FME Community.
