Removes selected palette(s) from raster features.
The RasterPaletteRemover receives raster features and removes any selected palettes.
To select specific bands or palettes, use the RasterSelector prior to the RasterPaletteRemover.
Cells are unaffected, retaining their original values.
If the source band has no palettes, the raster remains unchanged.
In this example, we have a single-band raster of land use zones, with an RGB palette. We want to remove the palette.
Note that the cell values are palette keys - in this case, a cell value of 6, which the palette associates with an RGB value.
The raster is routed into a RasterPaletteRemover.
This transformer has no parameters to configure.
The output raster feature has no palette, and the FME Data Inspector renders it as grayscale.
Note that the cell values are not changed, but the previously associated palette color has been removed.
In this example, we start with a single-band raster that has two palettes - one containing RGB colors, and one containing string descriptions. We want to remove the string palette. Note the band and palette numbers - they will be needed to select the correct palette for removal.
Note that the cell values are associated with both an RGB color and a string in the palettes.
The raster is routed first into a RasterSelector, where we will select the palette to be removed. From there, it is passed through the RasterPaletteRemover.
In the RasterSelector parameters dialog, with the Selection Mode set to Band and Palette List, we define that list as 0 1 - the band and palette numbers identified earlier. This represents the first band (0), and the second palette (1), as band and palette numbering starts at zero.
The RasterPaletteRemover has no parameters to configure.
The output raster feature has only one palette - the original RGB palette. The string palette has been removed.
Note that the cell values are unchanged, and are still associated with the RGB values from Palette 0.
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
RasterCellOriginSetter | Sets the cell origin point within cells in a raster. |
RasterConvolver |
RasterExpressionEvaluator | Evaluates expressions on each cell in a raster or pair of rasters, including algebraic operations and conditional statements. |
RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering either the extents of a raster or the extent of data within a raster. |
RasterGCPExtractor | Extracts Ground Control Point (GCP) coordinate system and point values from a raster feature and exposes them as attributes. |
RasterGCPSetter | Sets Ground Control Points (GCPs) on a raster, pairing cell positions with known coordinates. |
RasterGeoreferencer | Georeferences a raster by either known corner coordinates or origin, cell size, and rotation. |
RasterHillshader | Generates a grayscale shaded relief representation of terrain, based on elevation values. |
RasterInterpretationCoercer |
RasterMosaicker | Merges multiple raster features into a single raster feature. |
RasterPropertyExtractor | Extracts the geometry properties of a raster feature and exposes them as attributes. |
RasterPyramider | Resamples rasters to multiple resolutions, based on either number of levels or dimensions of the smallest output raster. |
RasterResampler | Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, and interpolates new cell values. |
RasterRotationApplier |
RasterSubsetter | Clips raster features using pixel bounds instead of ground coordinates, and optionally adds cells around the perimeter. |
RasterTiler | Splits each input raster into a series of tiles by specifying either a tile size in cells/pixels or the number of tiles. |
RasterToPolygonCoercer | Creates polygons from input raster features. One polygon is output for each contiguous area of pixels with the same value in the input raster. |
WebMapTiler | Creates a series of image tiles that can be utilized by web mapping applications such as Bing™ Maps, Google Maps™, or Web Map Tile Service. This is done by resampling rasters to various different resolutions and then splitting them into tiles. |
RasterBandAdder | Adds a new band to a raster feature. |
RasterBandCombiner | Merges coincidental raster features into a single output raster feature, preserving and appending all bands. |
RasterBandInterpretationCoercer |
RasterBandKeeper |
RasterBandMinMaxExtractor | Extracts the minimum and maximum band values, palette keys, and palette values from a raster feature, and adds them to a list attribute. |
RasterBandNameSetter | Sets the band name of selected bands on a raster, making raster contents simpler to understand compared to band numbers. |
RasterBandNodataRemover | Removes the existing nodata identifier from selected bands of a raster feature. Any values previously equal to the nodata value are considered valid data. |
RasterBandNodataSetter | Sets a new nodata value on selected bands of a raster feature. |
RasterBandOrderer | Specifies the required order of bands in a raster. Bands are reordered according to the input band indices. |
RasterBandPropertyExtractor | Extracts the band and palette properties of a raster feature and exposes them as attributes. |
RasterBandRemover | Removes any selected bands from a raster feature. |
RasterBandSeparator | Separates bands or unique band and palette combinations, and outputs either individual raster features or a single new raster feature containing all combinations. |
RasterStatisticsCalculator | Calculates statistics on raster bands and adds the results as attributes. |
RasterAspectCalculator |
RasterCellCoercer | Creates individual points or polygons for each cell in a raster, optionally extracting band values as z coordinates or attributes. |
RasterCellValueCalculator | Evaluates basic arithmetic , minimum, maximum or average operations on the cell values of a pair of rasters. |
RasterCellValueReplacer | Replaces a range of band values in a raster with a new single value. |
RasterCellValueRounder | Rounds off raster cell values. |
RasterSingularCellValueCalculator | Performs basic arithmetic operations on the cell values of a raster against a numeric value. |
RasterSlopeCalculator | Calculates the slope (maximum rate of change in z) for each cell of a raster. |
RasterPaletteAdder |
RasterPaletteExtractor | Creates a string representation of an existing palette on a raster and saves it to an attribute. |
RasterPaletteGenerator | Generates a palette out of the selected band(s) of a raster. The output raster will have the selected band(s) replaced by a new band with a palette. |
RasterPaletteInterpretationCoercer |
RasterPaletteNodataSetter |
RasterPaletteRemover | Removes selected palette(s) from raster features. |
RasterPaletteResolver | Resolves the palette(s) on a raster by replacing cell values with their corresponding palette values. Palette values with multiple components, such as RGB, are broken down and the individual values assigned to multiple, newly-added bands. |
RasterCheckpointer | Forces accumulated raster operations to be processed, saving the state to disk and releasing resources to tune performance or assist with memory limitations. |
RasterConsumer | Reads raster features for testing purposes, including any accumulated raster operations. No additional operations are performed, and nothing is done with the features. |
RasterExtractor | Serializes the geometry of a raster feature into a Blob attribute, encoding the contents according to a choice of common binary raster formats. |
RasterNumericCreator | Creates a numeric raster of specified size and resolution, with default cell values. |
RasterReplacer | Decodes a binary attribute containing encoded rasters stored as Blobs, replacing the feature’s geometry with the decoded raster. |
RasterRGBCreator | Creates a color raster feature of specified size, resolution, and interpretation type, with default cell values. |
RasterSelector |
ImageRasterizer | Creates a raster representation of vector or point cloud input features, using the fme_color attribute over a solid background fill for vector features. Point clouds may be rendered using their color or intensity components. |
NumericRasterizer | Creates a numeric raster representation of vector or point cloud input features, where cell values are taken from the z coordinates of the input features and overlaid on a uniform background. |
MapnikRasterizer | Generates a raster from input vector and raster features, with fine control over symbolization and labeling, using the Mapnik toolkit. |
PointOnRasterValueExtractor | Extracts the band and palette values from a raster at the location of one or more input points and sets them as attributes on the feature. |
RasterDEMGenerator | Produces a raster digital elevation model (DEM) by uniformly sampling a Delaunay triangulation generated from input points and breaklines. |
VectorOnRasterOverlayer | Rasterizes vector or point cloud features onto an existing raster. For vector features the fme_color attribute sets pixel color, and point clouds may be rendered using their color or intensity components. |
Raster features with any selected palettes removed. Cell values are unaltered.
INVALID_RASTER_NO_BANDS
A set of control characters is available in the Text Editor. | |
Working with User Parameters | Create your own editable parameters. |
Dependencies | None |
FME Licensing Level | FME Professional Edition and above |
Aliases | |
History | |
Categories |
Search for all results about the RasterPaletteRemover on the FME Community.
