RasterBandNameSetter
Sets the band name of selected bands on a raster, making raster contents simpler to understand compared to band numbers.
Jump to Configuration
The RasterBandNameSetter receives raster features and applies either a single name or list of names to the currently selected band or bands.
To select specific bands, use the RasterSelector prior to the RasterBandNameSetter.
Lists of names must be provided as an FME list attribute.
This transformer supports raster band selection. Palettes are unaffected.
Using a List Attribute for List of Names
When the input type is a list (Input Type = List of Names), a list attribute that contains band names must be specified.
The values in the list will be applied to the selected bands, in the order they were selected. The list must contain at least as many elements as there are selected bands. List values are used sequentially.
List Examples
Given an input raster feature with three bands and no band names, this table shows the expected output for different combinations of selected bands against the same list attribute of band names.
List Attribute*
Selected Bands*
(bold)
Resulting Band Names
_bandnames{0} = 'OneDog'
_bandnames{1} = 'TwoCats'
_bandnames{2} = 'ThreeFish'
0
1
2
Band 0: OneDog
Band 1: TwoCats
Band 2: ThreeFish
0
1
2
Band 0: OneDog
Band 1:
Band 2:
0
1
2
Band 0: OneDog
Band 1:
Band 2: TwoCats
0
1
2
Band 0:
Band 1: OneDog
Band 2: TwoCats
*Band numbers start at zero (0), as do list elements. The band name list attribute may have any name.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
FME Licensing Level FME Professional Edition and above
Aliases
History
Categories
Rasters
Search for all results about the RasterBandNameSetter on the FME Community.
