RasterInterpretationCoercer
Alters the interpretation type of rasters, including all bands, and converts cell values if necessary.
Jump to Configuration
The RasterInterpretationCoercer receives raster features and converts all bands based on a chosen Destination Interpretation Type. Choices include:
Options are available to control the manner in which cell values are converted, handling color to color, numeric to color, color to numeric, numeric to numeric, and floating point to integer conversions.
Band names, if they exist, are retained.
Multi-Band Rasters
When converting to an interpretation with multiple components, such as RGB and RGBA, the input raster will be expected to have exactly 1, 3, or 4 bands. If only one band is supplied, it will be cloned to create the correct number of bands for conversion to the chosen interpretation.
When converting to a single color or numeric interpretation, multiple input bands will be averaged into a single one.
Palettes
If bands selected for conversion contain palettes, the destination interpretation must be an unsigned integer - UInt8, UInt16 or UInt32 to accommodate the palette keys.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
FME Licensing Level FME Professional Edition and above
Aliases
History This transformer replaces the RasterDataTypeCoercer and RasterColorModelCoercer transformers.
Categories
Rasters
Search for all results about the RasterInterpretationCoercer on the FME Community.
