Creates series of raster tiles for use in web mapping applications such as Bing™ Maps, Google Maps™, or Web Map Tile Service. Tiles are produced at varying zoom levels, size, and resolution.
The WebMapTiler accepts raster features, and "pyramids" them - resampling and tiling them as necessary to produce a set of raster tiles appropriate for different zoom levels as required by various web mapping tile schemes.
The minimum and maximum zoom level may be specified, or left unset to produce the minimum and maximum level supported by the resolution and size of the input raster(s).
Tile size may be specified for some Tile Schemes. Various methods are available for interpolation of pixel values during resampling.
Attributes may be added to the output tiles to record zoom level, tile position, original raster index, number of tiles produced, and Quadkey (used for quad-tree based tile schemes).
This transformer is unaffected by raster band and/or palette selection.
Scheme |
Used for |
Projection* |
Tile Size |
Zoom Levels |
| GoogleMapsCompatible | Google Maps, Bing Maps, Web Map Tile Service, and ArcGIS. | EPSG:3857 (Spherical Mercator) | 256x256 pixels | 0 to 23 | ||||||||||||||||||||||||||||||||||||||||||||
At level 0, the entire world is represented by a 256x256 pixel tile. Each level increases the number of rows and columns by a factor of two: level 1 is 512x512, level 2 is 1024x1024, and so on. The number of tiles is increased accordingly - 1 tile, 4 tiles, 16 tiles, and so on. GoogleMapsCompatible zoom level 0 tiles (column, row):
GoogleMapsCompatible zoom level 1 tiles:
GoogleMapsCompatible zoom level 3 tiles:
| GoogleCRS84Quad | Web Map Tile Service | LL84 | 256x256 pixels | 0 to 18 | ||||||||||||||||||||||||||||||||||||||||||||
At level 0, the entire world is represented by a 256x256 pixel tile (where the first and last 64 rows of the tile are blank). Each level increases the number of rows and columns by a factor of two: level 1 is 512x512, level 2 is 1024x1024, and so on. |
| GlobalCRS84Scale | Web Map Tile Service | LL84 | user-defined | 0 to 20 | ||||||||||||||||||||||||||||||||||||||||||||
Spacing is defined in degrees for each level.
| GlobalCRS84Pixel | LL84 | user-defined | 0 to 17 | |||||||||||||||||||||||||||||||||||||||||||||
This scheme defines a spacing in degrees for each level, as follows:
*Incoming rasters that are not in the required projection will be reprojected by the transformer before tiling is carried out.
In this example, we prepare a single 4800 x 4000 orthophoto of Vancouver (at 1 meter resolution) for use in Google Maps. The source image is a single GeoTIFF. Note that the projection is UTM83-10 - the transformer will need to reproject it before resampling and tiling.
The raster is routed into a WebMapTiler.
In the parameters dialog, we choose GoogleMapsCompatible as our Tile Scheme.
Note that the Zoom Levels have been left blank. The transformer will calculate the appropriate minimum and maximum levels that can be produced from the input raster.
The zoom levels, as well as the size and position of the tiles for each level, are fixed by Google Maps. The WebMapTiler will adjust the output rasters to fit into these standards.
A total of 740 tiles are produced from the original. The number of tiles per zoom level can be analyzed with a StatisticsCalculator.
Note that only zoom levels 5 through 17 have been produced (out of all possible levels, from 0 - the entire earth - to 23 - the smallest possible area of coverage given the original image size and resolution).
Zoom Level 10
Examining the single tile output for zoom level 10, note the new attributes added including tile position, zoom level, quadkey (used by Google Maps), and more.
The extent of the original raster falls wholly inside the extent of this standard tile’s size and position, so the raster has been padded with blank cells.
A close view of the portion of the raster containing the original shows the resampling to an appropriate (lower) resolution.
Zoom Level 15
42 tiles were produced for zoom level 15.
A closer look at the selected tile clearly shows that higher resolution is retained for higher zoom levels.
To resample rasters using zoom levels and positions that are not tied to one of these web mapping tile schemes, consider using the RasterPyramider.
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
| RasterConvolver |
| RasterRotationApplier |
| RasterBandKeeper |
| RasterAspectCalculator |
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
| RasterSelector |
Tiles with additional attributes, produced according to the selected Tile Scheme and other parameters.
| Tile Scheme |
Choose a method for tiling data. Choices include:
See Tile Schemes above for more detail. |
These parameters specify the zoom levels for which tiles will be generated. Valid values vary by Tile Scheme - see Tile Schemes above for more detail.
If these values are left blank, the transformer will calculate an appropriate range of zoom levels based on the input raster.
| Minimum Zoom Level |
(Optional) Specify the minimum zoom level to be generated. If Minimum Zoom Level is unspecified, the minimum zoom level will default to the minimum level at which the raster is visible. Note that tiles will not be generated if the input raster covers less than 1 row and 1 column at a particular zoom level, regardless of the minimum zoom level value. |
| Maximum Zoom Level |
(Optional) Specify the maximum zoom level to be generated. If Maximum Zoom Level is unspecified, the maximum zoom level will be the smallest zoom level such that the resampled raster has more rows or columns than the original raster. |
These parameters specify the size of each output tile for tile schemes that support user-defined sizes.
| Number of Columns | Specify the desired tile width in cells (pixels). |
| Number of Rows | Specify the desired tile height in cells (pixels). |
| Interpolation Type |
Cell values are interpolated to produce various raster sizes and resolutions. Choose a method:
If attribute names are specified, new attributes are added to the output tiled rasters.
| Quadkey Attribute |
If specified, an attribute will be added to each output feature specifying the quadkey for that tile. Quadkeys are used by Bing Maps to uniquely identify a single tile at a particular level of detail. Note that this attribute will only be created for quad-tree based tile schemes (GoogleMapsCompatible and GoogleCRS84Quad). |
| Zoom Level Attribute | If specified, an attribute will be added to each output feature specifying the zoom level of that tile. |
| Tile Column Attribute | If specified, an attribute will be added to each output feature specifying the column of that tile. |
| Tile Row Attribute | If specified, an attribute will be added to each output feature specifying the row of that tile. |
| Raster Index Attribute |
If specified, an attribute will be added to each output feature that identifies which raster it was created from. This index is zero-based, so all tiles created from the first input raster will have a value of 0, all tiles created from the second input raster will have a value of 1, etc. |
| Number of Tiles Attribute | If specified, an attribute will be added to each output feature identifying the total number of tiles created from the input raster, across all zoom levels. |
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| Aliases | VirtualEarthTiler |
| History | This transformer was previously named the VirtualEarthTiler. |
| Categories |
Search for all results about the WebMapTiler on the FME Community.
