RasterPaletteInterpretationCoercer
Alters the interpretation type of raster palettes.
Jump to Configuration
The RasterPaletteInterpretationCoercer receives raster features and alters the interpretation type of selected palettes, adjusting palette values if necessary.
Palettes may be converted to:
A variety of options are available, depending on the Destination Interpretation Type, to specify how value conversions are handled when:
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
FME Licensing Level FME Professional Edition and above
Aliases
History
Categories
Rasters
Search for all results about the RasterPaletteInterpretationCoercer on the FME Community.
