Sets a new nodata value on selected bands of a raster feature.
The RasterBandNodataSetter receives raster features, and adds or changes the nodata property on any selected bands. If a band already has a nodata value, cells with that value may optionally be changed to the new provided value.
Nodata represents an absence of data, and cells that have (or receive) the new nodata value are ignored for most calculations, and are transparent when viewed in the FME Data Inspector and many other visualization tools.
All selected bands on an input raster feature will receive the same specified nodata value.
To select specific bands, use the RasterSelector prior to the RasterBandNodataSetter.
This transformer supports raster band selection. Palettes are unaffected.
In this example, we have a numeric raster of planning zones, with cell values between 0 and 10 representing the zone type. Zero (0) represents areas that are not included in a valid zone, and so we want to designate those as nodata, and invalid for calculations.
Note that the original raster does not have a Nodata Value included in band properties.
Cells with the value of zero are displayed as black, and are considered valid.
The raster feature is routed into a RasterBandNodataSetter.
In the parameters dialog, Nodata Value is set to zero (0).
Note that the Replace Cell Values option is not relevant to this workflow, as the incoming raster does not have a nodata value already set, with existing values to change.
The output raster feature has a Nodata Value band property now, set to zero (0).
Note that the nodata cells are now rendered as transparent in the FME Data Inspector. The cells still have a value of zero, but are designated nodata.
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
| RasterConvolver |
| RasterRotationApplier |
| RasterBandKeeper |
| RasterAspectCalculator |
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
| RasterSelector |
Raster features with nodata values added or modified as specified on selected bands.
INVALID_RASTER_NO_BANDS
| Nodata Value |
Specify a numeric value to be set as the new nodata value. If a nodata value already exists, it will be replaced. |
| Replace Cell Values |
No: Cell values are not altered. If a raster already has a nodata value defined, and has cells with that value, they will retain their original values and become valid. Yes: If a raster already has a nodata value defined, any cells with that value have their values changed to the new nodata value. If the raster contains cells with both the original and new nodata values, original value cells will be changed to the new value and still considered nodata, in addition to any cells that already had the newly defined nodata value. If the input raster does not already have a nodata value defined, Yes will have no effect and cell values are unchanged. |
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| History | |
| Categories |
Search for all results about the RasterBandNodataSetter on the FME Community.
