Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, by interpolating new cell values.
Reducing raster resolution (by reducing the number of cells and increasing cell size)
The RasterResampler accepts raster features and alters the number of rows/columns and resizes cell (pixel) size according to the parameter selections. One raster feature is output for each input feature.
Output raster resolution may be specified by set dimensions (columns and rows), cell size in ground units, or percentage of original resolution.
A variety of methods are available for output cell value interpolation.
A: Original resolution
B: Desired resolution
C: Desired resolution compared to original
D: Resampled output raster
In this example, we will resample an orthophoto. The original raster is 1600 x 1000 pixels, with a cell size (Spacing) of 1,1 - one meter wide by one meter high (the ground units of the projection).
The raster is routed into a RasterResampler.
In the parameters dialog, we select the Size Specification of CellSize. This enables the X and Y Cell Spacing parameters, which are then both set to 25 - meaning 25 meters in ground units.
Interpolation Type is left as the default of Nearest Neighbor.
The output raster covers the same geographic extents as the input, but the cells are now 25 meters square and the resolution has correspondingly decreased to 64 x 40.
Although this transformer can be used to increase raster resolution, usually there is little benefit in doing so (with an exception being to match the resolution of other raster data for processing purposes).
| RasterConvolver |
| RasterRotationApplier |
| RasterBandKeeper |
| RasterAspectCalculator |
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
| RasterSelector |
One resampled raster per input raster feature.
INVALID_RASTER_NO_BANDS
INVALID_PARAMETER_NUMBER_OF_ROWS
| Size Specification |
Select a method for specifying output raster size. Options include:
| Number of Columns (cells) | If Size Specification is RowsColumns, specify the desired raster width in cells (pixels). | ||||||
| Number of Rows (cells) | If Size Specification is RowsColumns, specify the desired raster height in cells (pixels). | ||||||
| X Cell Spacing | If Size Specification is CellSize, specify the desired cell (pixel) width in ground units. | ||||||
| Y Cell Spacing | If Size Specification is CellSize, specify the desired cell (pixel) height in ground units. | ||||||
| Percentage |
If Size Specification is Percentage, specify the desired percentage. This number must be greater than 0, and may be greater than or less than 100. 100 is equal to the input size. |
| Interpolation Type |
Cell values are interpolated to produce various raster sizes and resolutions. Choose a method:
| History | |
| Categories |
Search for all results about the RasterResampler on the FME Community.
