FME Transformers: 2025.1 BETA
Categories
Rasters
Spatial Analysis
Related Transformers
FeatureColorSetter
ImageRasterizer
MapnikRasterizer
NumericRasterizer
PointCloudOnRasterComponentSetter
RasterNumericCreator
RasterRGBCreator
VectorOnRasterOverlayer
Rasterizes vector or point cloud features onto an existing raster. For vector features the fme_color attribute sets pixel color, and point clouds may be rendered using their color or intensity components.
Jump to Configuration
  • Imprinting vector data onto an existing raster background (such as orthophotos)
  • Updating a raster image from vector data
The VectorOnRasterOverlayer receives vector geometries (points, lines, areas) and/or point clouds, and rasterizes them onto an input raster feature, producing a single output raster.
For vector input features, the fme_color attribute determines the pixel color in the raster. Pixel values for red, green, and blue bands will be taken from the corresponding component of a feature's fme_color attribute. Pixel values for gray bands will be the average of the fme_color components.
Polygonal features may also optionally have an fme_fill_color attribute; in this case, the outer boundary will be drawn using fme_color and the inner area will be drawn using fme_fill_color.
For point clouds, pixel coloring may be done using either the color or intensity component.
The Z coordinates of the input vector features are used to generate pixel values for numeric bands.
Line weights are not supported, and features will be drawn at a width of one (1) pixel. Lines and points may be buffered prior to entering the transformer to increase their visibility.
Alpha value and anti-aliasing options are available. The resolution, extents, and interpretation of the output raster will be identical to the input raster.
Vector data extents do not need to match the extents of the raster - if they extend beyond the raster, they will be clipped.
Attributes from the input vector or point cloud features may be merged onto the output raster, with a list attribute option available.
Features with no color attribute (or point clouds without an intensity component, if selected) will be discarded and output via the <Rejected> port, as will extra or invalid raster images.
Aggregate rasters are not supported, but they may be deaggregated and mosaicked prior to entering the transformer. Aggregate vector data may be rasterized, but may produce duplicate records if a list attribute is created.
Rasters with palettes are not supported.
This transformer supports raster band selection. The RasterSelector can be used to modify selection.
  • To rasterize vectors/point clouds and create a new raster (not drawing on an existing one), use the ImageRasterizer.
  • To add labels, you can use a Labeler and TextStroker prior to the VectorOnRasterOverlayer.
  • For fine control over cartographic styling, consider using the MapnikRasterizer.
  • If your background raster spans more than one image, use a RasterMosaicker prior to the VectorOnRasterOverlayer.
  • To produce elevation rasters, use the NumericRasterizer.
  • To increase size and visibility on vector features, consider using the Bufferer.
  • To colorize a point cloud from a raster, use the PointCloudOnRasterComponentSetter.
  • If a raster has a palette, use a RasterPaletteResolver prior to the VectorOnRasterOverlayer.
Choosing a Raster Transformer
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the VectorOnRasterOverlayer on the FME Community.
